agreed and my wife will legit kill me for revving it up in the driveway during 1 of 3 of our kid's naps lol. I'll literally be driving around the hood w/no home until the 3 minute window between naps hahahLol aint nobody got time for that
Haha I forgot about that! No wonder I couldn’t find that thread.What happened to that thread with the Australian fella about chillers?? It was full of useful information until it went off the rails and turned into a pissing match lol.
Yeah that would be annoying go have to do that. Plus the looks you would get all the time when you are parking around town hahaLol aint nobody got time for that
fiinterchillers.com
Not sure if you are aware but we are talking about two separate types of condensation leaks. External and internal.Looks like the FI kit claims no condensation leaks, not sure how they would be able to get around that. Plus seems like you can run normal and then have it wired up to do "race" which would then turn off cabin AC and cool charged air only. Can anyone running this system confirm?
Interchiller Ram TRX Stage 2 – Fi Interchillers Online Store
Ram TRX is a stage 2 only kit Turning any temperature into freezing cold winter! Race Track Safe Improves fuel consumption No condensation leaks Gain back ignition timing Once your intercooler fluid passes through the chiller is is supercooled to below freezing temperatures which then lowers...fiinterchillers.com
You are correct. When the lines are wrapped you will get no/minimal condensation. Also yes race valve to cut cabin ac to further chill the IC coolant.Looks like the FI kit claims no condensation leaks, not sure how they would be able to get around that. Plus seems like you can run normal and then have it wired up to do "race" which would then turn off cabin AC and cool charged air only. Can anyone running this system confirm?
Ah ok, yes that makes complete sense. Read though it to quickly.Not sure if you are aware but we are talking about two separate types of condensation leaks. External and internal.
They claim no leaks and that applies to external from their own system. They provide insulation to help with this and allows you to run the system on the track since you cannot be dripping water at a drag strip.
The internal condensation leaks within the IC system (which they cannot control) are unavoidable with the hellcat design.
I have run their stage two on a previous vehicle and can confirm.
Is the ripa one funning full blast or does it have stages like the F1? I see the FI one you can run normal and Race.You are correct. When the lines are wrapped you will get no/minimal condensation. Also yes race valve to cut cabin ac to further chill the IC coolant.
I went with the Ripatuned IC after much debate and head scratching between them and FI. My ultimate decision was based on the ease of installation and the 2.5 gallon reservoir tank (FI is releasing one soon) Ripa has a race valve as well wired to an aux switch. I am still in the process of insulating the rest of the factory lines which I should button up tomorrow.
Both the Ripa and FI kits can be installed and removed easily it sounds like now that FI has updated their TRX kit to their full plug/play style. The other thread with all the details from the FI kit would be helpful to have reinstated. Lots of good technical content and there was direct stated experience from folks with both kits providing performance. I believe FI was providing the superior performance by about 20 F greater reduction in IC temps.Is the ripa one funning full blast or does it have stages like the F1? I see the FI one you can run normal and Race.
I really like the idea of Ripa easy to install and removed.
Ac on in cab runs the chiller and cab ac with no affect to the vent temps. I hit aux 6 and shuts the cab ac off and chiller only gets it.Is the ripa one funning full blast or does it have stages like the F1? I see the FI one you can run normal and Race.
Do you have any tuning on it? I believe it can be improved with tuning. I’ve only had one occasion where mine failed to start and it was 85-90° outside. And that’s on e85. We have similar weather conditions and I’ve had no trouble today.I experienced my first "no start" today. A little humid today, but only 73 out. IC coolant was around 58 when I pulled up to the gym. About an hour in the gym, went to leave and it just cranked over and over. Stopped it and it restarted normal. Very annoying if this is every time...or sometimes. I'll try shutting it off a few mins before my destination and see what that does.
No tune. Incognito lower, AFE super stock intake, Borla Atak exhaust.Do you have any tuning on it? I believe it can be improved with tuning. I’ve only had one occasion where mine failed to start and it was 85-90° outside. And that’s on e85. We have similar weather conditions and I’ve had no trouble today.
Likely need to tune to adjust the fuel startup tables if just the wrong conditions pop up.No tune. Incognito lower, AFE super stock intake, Borla Atak exhaust.
Looks like Dusterhoff will be getting a callLikely need to tune to adjust the fuel startup tables if just the wrong conditions pop up.
Do it! LolLooks like Dusterhoff will be getting a call![]()
The ones I have seen personally (FI, IC and WeaponX) are all different. And there is a difference in quality.Are all the chiller condensers made by the same manufacturer and is there differences between the aftermarket brands?
