Your Stealer will try to convince you to change it every time you bring it in for an oil change if you're gullible enough to let them...Without looking at the recommended schedule, what is the mileage recommended?
My vf2065 slid right in. There was a little friction from the passenger side so I had insert the driver side tip in first, but only a bit. With a little pressure it just goes right in. I jiggled it back and forth to make sure it was well seated. That was the first time I did it. I expect the door will loosen up over time and I will have no problem just poppin one out and in.
