1/4 Mile Times 🏁
As you can see the performance pages aren’t very accurate but she’s moving out. Looking to do an interchiller and drop pulley size next.
October 10th
Mid Michigan Motorplex
2.75 upper
E85 Tune
180 thermostat
1100cc injectors
Nitto 420v on 20” wheels
Just curious….. did you dyno your TRX? If so what’s your rwh?
October 10th
2.75 upper
E85 Tune
180 thermostat
1100cc injectors
Do you have any pics of your truck on the 20" wheels and Nitto 420v's?
Best on I've got on the on board, either factory freak or computer is way off.
Stock truck, flat road no wind,
2k manual launch in sport mode with tc off
Heartland Park Topeka
77 degrees, 15mph head wind.
2021 Ram TRX Lvl 1
6700lbs with driver, spare removed, 3/4 tank.
Litens 2.85, IDX1050 Injectors, 93 tuned, everything else stock.
12.09 @ 111.06
Josh from HHP was graciously trying to dial in my tune on Saturday but the test and tune folks were running behind bracket racers so we were doing a run every 1.5hrs. I could only get 2 passes in. I haven't launched yet so I think high 11s is well within reach especially without the head wind and cooler temps. Next will be race fuel tune which can be much more aggressive. Targeting 11.5-11.6.
You're not going to have a problem reaching your goals. I ran 11.95 with just a incognito lower. 111 mph. The weather was hurting you.
Keystone raceway park- Pittsburgh pa.
12.23 @ 110mph
2022 TRX lvl 2
4/29/22
Stock wheels/tires
No mods all stock
Full tank of gas and spare tire on
Track/Location = Heartland Park Topeka
1/4 Mile Time/MPH = 11.61 @ 116.41
Year / Model / Trim = 21' TRX Level 1
Date = 6/10/22
Tires = Stock
Mods = HHP Stage 1 Kit (Litens 2.85 Pulley and ID1050 Injectors), Race Fuel and Trans Tune
Track Conditions = 80F, 5-7mph headwind, DA 3600, inlet air temp 140F.
Date = 6/10/22
Tires = Stock
Thats awesome. I live in KC and would like to try out the drag strip sometime. When is it open?
If you go to Heartland Park Motorsports and click on "Events" there is a schedule for June - October. The evening test and tunes (my preference for cooler weather, max runs, and cost) are typically on Friday's. They also have early afternoon Saturday test and tunes but you follow behind bracket racers so you get 1 pass every 45-60 minutes. The next one is June 17th:
Finally Friday Night Drags presented by Edgar’s Transmission
Drag Strip
Test & Tune Tech Card $35.00
Adult Spectators & Crew Members $10.00
Kids 6-12 $3.00
Kids 5 & Under Free
Gates open at 4:00pm; Track Hot 5:00pm – 9:00pm
Date = 6/10/22
Tires = Stock
Updated!
I'm on the left for the time slip. Density altitude for the day was 9388, ugh. Half a tank of gas and a lot of wheel spin, but it is what it is, lol. With all the mods I would believe I could do better, but it's going to at least take getting better tires.
GRIPTEC 2.75 UPPER PULLEY
ATI 10% LOWER PULLEY
CRANK PINNING KIT
GATES GREEN RACING BELT
FUEL INJECTOR UPGRADE / ID1300X
BOOST A PUMP
BOOST REFERENCE ADAPTER
180 DEGREE THERMOSTAT
Forced Inductions Supercharger Spacers + Thermal Blankets
Kong Performance Ported Snout + Bearing plate / Max Effort Full Port
Williams 108mm Throttle body
Hellcat/Demon Kong Performance Super Charger Rebuild
STAINLESS WORKS RAM TRX 6.2L LONG TUBE HEADER KIT
Magnaflow XMOD exhaust (Extreme Delete)
Custom Grind Performance Camshaft
BWoody CAI
CUSTOM TUNING E85 (PCM and TCM) by ZHTunes
