I believe the side windows were about 15-20% which pretty much matched the factory tint on the back side windows. They did 50% across the rear windows. I went with the highest heat reduction ones they had.
Regarding the windshield there is an earlier thread on this and potential problems it can cause. Essentially the water can run down between the dash and the windshield and get a module wet that impacts all of the trucks electronics. I believe it is located on the drivers side under the dash. My installer used additional water barriers along the windshield and covered the module beneath the dash. I was a little nervous about doing it but since my installer was familiar with the potential issues and had done other TRX I felt more comfortable. I think a number of other people have done the windshield without issue and mine did not create any issue. If you can find the previous thread dealing with this you can get more details as I know at least one person did have a problem with this happening.
Good luck, it's worth doing the windshield tint in my opinion, just make sure they use extra care when doing it.
Thanks for the information. I found the thread and posting for context.
As long as the shop doing the tinting is aware of the BCM issue and placement then all should be good. Since all RAMs are similar, a well-versed shop that specializes in tinting should know about and be aware of the issue. I’ll still bring this up to the shop on Wednesday when I drop it off.
Thanks again.
I had the front windows tinted, installed the bed cover, bed rug and Go Rhino running boards. After that, I washed the toys.
Got the windows tinted. I also put the clear ceramic on the windshield as I had it on the Raptor and it really helped with the heat here in Florida. I was a bit concerned to have the windshield done because of the issues of water getting behind the dash and messing up the electronics for the truck. The place I used was very familiar with that issue, took extra precautions to protect the under dash electronics and had done others before mine without a problem. Everything went perfectly with no problems.
I also added an Undercover Armor Flex bed cover.
Hi, what percentage did you do your windows? And where in Fl did you get them done? Very nice looking truck…
Thanks, I had the front side windows done to match the rear side windows factory tint so it was like 15 which may be marginally lighter than the rear sides but not much. I went with 50% across the back and just clear on the windshield. I am in the Palm Harbor/Clearwater area. Loving this truck more everyday.
I‘m in Clearwater just south of Safety Harbor. Just picked mine up from dealership in Pa and made the drive back. No regrets. Who did you use for the tint?
Congrats, you are close. What color did you get? I used Precision Window Tint in Palm Harbor on Alt 19. Ryan or Kevin, 727-385-8788. They did my Raptor a little over a year ago too and I have been satisfied with their work both times.
White, level 2, all options less decals, roll bar & spare tire mount. Ordered July. Arrived at dealer March 12
What did I do to mine? I drove it for the first time after waiting 6 months!
Such a cool vehicle.
Similar time line to mine. Hope to see you on the road. I know of a couple of others here in Palm Harbor and Hulk Hogan is running around in his.
Changed them fluids. And installed Valvomax valves to make it a bit easier next round.
This is a poor pic of the valve with the drain hose connected. Bent from being in the packaging, but hopefully you get the idea.
Using SRT oil filters:
I got my front driver and passenger side windows tinted, along with a darker tint on the sunroof.
Can you explain to me the benefits of the SRT oil filter as opposed to, say, a NAPA gold filter? Thank you.
I personally run the SRT filter because it’s a nice upgrade while still being a Mopar part (just in case). It’s not the greatest filter in the world and it’s overpriced. But it is well made and should perform much better than the stock MO-899.
The SRT one is made by Wix (just like the Napa Gold) but from what I understand there is no exact Wix equivalent.
Thank you!
