I got XPEL ceramic tint. Yes front windows got tint match to rears and the rear passenger, rear, and windshield all got clear/70% ceramic tint.
On my truck at first I did the fronts close to match the rears and a 5% sun strip. That was was ok but wanted more. It's going in on Monday to have ceramic 35% with 5%sunstrip on the windshield. Then I'll eventually take it back to have 10% all the way around on doors and rear window.
Installed AAD pulley tensioner due to belt slipping after dropping upper pulley size. Easy install, much better pulley coverage.
This is the second year applying Woolwax undercoating. The undercoating kit simplifies the job using a compressor set at 90 to 100 psi.
woolwax 5 Gallon Undercoating Kit Bundle w/PRO Gun & 2 Wands. Straw (Clear) Color.
Used these drop cloths, along with some painters tape, to protect the exhaust:
Oudain 25 Pieces Painters Plastic... https://www.amazon.com/dp/B0BZP682B3?tag=ramtrx05-20
woolwax 5 Gallon Undercoating Kit Bundle w/PRO Gun & 2 Wands. Straw (Clear) Color. https://www.amazon.com/dp/B07NLBR9PY?tag=ramtrx05-20
I applied ACF-50 to my undercarriage the last two winters. It worked pretty well, but this time I went in a completely different direction. It's not as cheap, but it's 100% guaranteed to keep my undercarriage corrosion free. As a bonus, it will prevent my TRX from being stolen from the airport parking lot. 🤣
Does that stuff stink as bad as Fluid Film? Love the product but man, I hate smelling it for weeks after.
Pretty new to the forum and this is my first post. Just had my 2022 vinyl wrapped, gorilla lugs installed, borla atak exhaust installed, mud flaps put on, BWoody air intake, AFE throttle body spacer, screen protector, all within the bast couple weeks. Next up is a new grill, new tow hook cover in black, 2 10" JLs get installed next Tuesday and power side rails will be here by the end of the month. What should be next?
You need a bigger garage if your TRX only clears the garage door by an inch 😜
Yeah, it looks like it's touching the garage door, but it was about 6" away. I've been using my 360° camera to judge when it's far enough in to clear the door. It is a tight fit...it only has about 6'-8' of clearance in the front. 🤣
Just got mine back from wrap/tint/PPF last Friday. Wheels, Bakflip and BedRug yesterday. Mod/Tune next week and bumpers the following week.
-Orafol wrap
-XPel (T) Ultimate Plus Stealth (Nose)
- PhotoSync IRD 15% tint all around
-Anderson Composites front hood/lights/grille trim.
-Vossen HP6-4 wheels
- Toyo AT III tires (35")
-Bakflip MX4
-BedRug
-Orafol wrap
-Bakflip MX4
-BedRug
Beautiful job! Totally bad-assed. How long do these wrap jobs last?
Thanks so much!
That's a good question, and one I did ask. Orafol is 4.25 mil, so it's a bit thicker than more common material, such as 3M. I had ceramic applied over the wrap, which should give me at least 5 years in Arizona. I could stretch that if I boost the ceramic once or twice per year. I'm outdoor 24/7, so I'll be happy with 5 or 6 years.
