How often would you need to replace the outer cast portion as opposed to the inner that is not the one piece design? Failure rate of the housing vs guts?That patent shows the turbine and exhaust housing cast with the cylinder head. The abstract states it right out the gate. The compressor housing and guts can be removed but turbine housing and manifold are integral.
Per the original question if a customer has an issue with his turbo could they not just replace parts inside? understand the outside is a one piece, but your still able to replace parts inside right?
If the housing wasn’t cracked you could rebuild the whole turbo?
Asking seriously just by looking at “sheet 2” of the patent. It looks like everything but the manifold can be replaced. So in theory they wouldn’t order you a new manifold for a turbo issue, just rebuild the one on the car currently.
