Hello, all. Don't want to plug my own company, but we sell a lot of aftermarket wheels. I won't post our site here, as I don't want to cross any lines or forum rules on advertising. If you PM me, I can get you our site and info we may be able to pass on. Now, let's talk about the TRX!
The difficult thing is the offset. Until we get TRUE specs on the stock wheels, we won't know exactly where to go with them. The bolt pattern is 6x5.5", though, same as the newest 1/2 tons. Also same as GM. I personally like the look of oversized wheels with a little less sidewall. However, WEIGHT is a big factor, regardless of horsepower. You have to remember 702 horsepower is a figured by Tourque*RPM/5252. Well, when you're at a dead stop, you're going to be at lower RPM. The torque number here makes a big difference. On diesel engines, the bigger wheels don't have as much of an effect as they are torque monsters, although not high horsepower. Take, for instance the new Ram 3500. You can get the high output cummins that puts out 1,000 LB-FT or torque! However, it still only has 400 hp, because it does not rev as high like a gasoline engine. However, big wheels also do not affect acceleration as much as with a gas engine. With a gas engine, you will have less torque on the lower end, so to get heavier wheels moving, it a lot more of your low-end power.
In my Supercharged Ram 1500, I had an estimated 500hp at the crank (Magna's estimate of 25% hp gain). In the summer I liked to run 37x13.50R24 tires on 24x12 wheels. Total weight was about 145lbs at each corner. Ridiculous, I know, but it looked cool.
In the winter, I ran 35x11.50R20 tires on 20x9 wheels. Weight dropped to just under 100lbs per corner. When I changed them in the fall, my truck felt like a fkn rocket compared to summer on the 37's!
With the TRX, I will have my first truck that I leave the suspension completely stock (at least for awhile). I want to go with a 20 or 22 inch wheel with a 35 inch tire. However, I want to keep the weight in check, so I may be looking around at forged off-road style wheels to try to keep the weight down a bit. Unfortunately, that usually comes at a hefty price tag. On top of that, a lot of the forged wheels really aren't that light compared to cast. When I get my truck, I'll pull the wheel off and check the offset stock and go from there. I'll try a few different setups and post pics of different stances to get some ideas on where they sit on the truck. If you guys have requests on WHICH wheels you want to see on the truck, let me know and I'll see if I can get pics of that same style to give you a better idea of what it looks like on the truck. BTW, mine will be Black, but I plan on wrapping it in matte grey, depending on what weather looks like here in MN. I was hoping to have the wrap on the truck before the paint sees and salt/snow on the roads. However, in Minnesota you never know! We're supposed to get like 3-5" of snow tonight and tomorrow, so if it continues like that and the roads continue to be a mess, I'm going to wrap it right away.
