I’m interested in going street tires and a bigger wheel. Will be curious to see if anyone else is going this route? Fender gap makes me shudder so that’s gonna be a challenge to fix!
There was a thread somewhere where we were talking about this but I don't remember where it was so in a nut shell if you want to keep close to the OEM diameter and radius the only option currently available for a street performance tire is:I’m interested in going street tires and a bigger wheel. Will be curious to see if anyone else is going this route? Fender gap makes me shudder so that’s gonna be a challenge to fix!
What are you doing for offset?Has anyone confirmed the lug pattern? I want to go ahead and order my wheels now so that they are here when the truck gets here. Thanks
[/URL]
In 325/50/22
It has a speed rating of 149 mph and a load rating of 2806 each if you are planning on removing your electronic governor of 118 mph. The OEM wheel is 34.6 by 12.8 and this wheel is 34.8 by 12.8 so your stock spedo wheel gap etc should be close enough to leave stock...
My plan is to run the street wheels and tires for daily driving and throw the OEM wheels and tires back on for off road trips and maybe winter. The stock wheels weigh something crazy like 100 pounds for each wheel and tire combo and depending on which wheels you get you could cut that rolling weight almost in half which would greatly increase your street performance and acceleration with these tires.
You are correct on the weight of the tires I sent, I have been going back and forth with my tuner to see if they are going to be able to unlock it and adjust the spedo for smaller wheels and remove the electronic governor and the mickey thompsons on 18 inch forged race wheels is where I was getting my cutting the rolling weight in half. if you swap out for a street tire that is the same diameter as the OEM you can save some weight on the larger wheels over the gigantic sidewall of the OEM rubber but most of your performance increases would be in handling and waaaaaay less road noise (yes that is a technical amount).Good luck with your street ties..
The cut the weight in half claim though is a bit of a stretch...more than a bit actually.
The 22 inch tires you quoted are 54lbs each.. a 325/65/18 tire as stock weighs high 60s....an 18 inch cast wheel will weigh high 20s..let's say this truck wheel weighs 30. A 22 cast will weigh mid 30s..
So stock is as you state about 100 per corner.
22s will be 90...
Just my opinion but this truck will look ridiculous with 22s on it... while gaining very little to nothing...
But opinions vary hahaha
This is nothing nowwhat, you should see some of his other posts lol! 22's with a performance tire will get you in the 3s?! How, not hooking up is not the issue as it launches in all wheel drive. Also, anyone that knows anything about dragging knows that sidewall is your friend as it has the potential to wrinkle. Road noise will not be an issue with these stock tires but its funny that you state that as positive and do not consider a much worse ride a factor? Brad you just have a seriously warped view of how things actually work. Its somewhat comical, I just worry about the people coming here for good info. Agreed your truck will look horrible on 22s, and will perform a lot worse off road and on. Good luck and please post pics of it with 22s when you get there so we can all get a good chuckle.Good luck with your street ties..
22s will be 90...
Hey TROLL try reading the post above the one you just posted where I talk about the decision between running near OEM size and reducing it down with some Mickey Thompson Drag radials on 18sThis is nothing nowwhat, you should see some of his other posts lol! 22's with a performance tire will get you in the 3s?! How, not hooking up is not the issue as it launches in all wheel drive. Also, anyone that knows anything about dragging knows that sidewall is your friend as it has the potential to wrinkle. Road noise will not be an issue with these stock tires but its funny that you state that as positive and do not consider a much worse ride a factor? Brad you just have a seriously warped view of how things actually work. Its somewhat comical, I just worry about the people coming here for good info. Agreed your truck will look horrible on 22s, and will perform a lot worse off road and on. Good luck and please post pics of it with 22s when you get there so we can all get a good chuckle.
Going back and forth with your tuner lol!, how would he know at this point? What was the point of the 22" post and defending it then? Also a dealer can adjust for just different tire/wheel sizes FYI. Then you say your consulting him for unlocking for a smaller wheel size and talking about 18s, even though stock are 18s, and it doesn't matter anyway because the adjustment would be for tire size? Ooof da. Good luck.Hey TROLL try reading the post above the one you just posted where I talk about the decision between running near OEM size and reducing it down with some Mickey Thompson Drag radials on 18s
TROLL.....
Nah really? Everyone knows that, your point is? I have a asked a bunch of questions and made good points calling you out on another post with the thought process of a mental patient. None if which you addressed, or could, so took the usual route of name calling. Hey, what's the inside scoop from your tuner!? Lol, what a moron.Mickey thompson doesn't make a 35 inch tire you internet 12 year old TROLL. Let the grownups talk and go troll elsewhere please and thank you
My fault I had a mental lapse and forgot you won't shut your yap unless we keep it to simple one word answers so.....Nah really? Everyone knows that, your point is? I have a asked a bunch of questions and made good points calling you out on another post with the thought process of a mental patient. None if which you addressed, or could, so took the usual route of name calling. Hey, what's the inside scoop from your tuner!? Lol, what a moron.
SadMy fault I had a mental lapse and forgot you won't shut your yap unless we keep it to simple one word answers so.....
TROLL
TROLL
And as far as looks goes beauty is in the eye of the beholder and I've always been a function over fashion kind of guy so if just by swapping out my wheels and tires for something that "looks off" means I can get this beast down into the 3s for 0-60, I don't have to look at it while I'm getting thrown back in my seat blowing the doors off of other mid life crisis 2 seater cars that cant do anything else
but to the OP the set up I originally posted will solve your desire for larger wheels with street tires without any extra fender gap
Very nice truck,Well again I wish you success.
28 inch tall drag radials are going too look like a wheelbarrow tire on this truck... as there is no wheel spin with launch control not sure you are going to like the result. Not to mention the truck constantly trying to over power such a small tire
Those drag radials are for 3500lb cars.. the load rating is very low in comparison.
Also the stock tires are very mild in tread so there won't be any noise
I have spent some time trying to get a 3 ton plus truck to move. A 1.6 60' with 1200 hp proves i got into the low 3s... and was able to get into the 10s for the quarter...needed a bunch of side wall..and shit tons of mods... getting a vehicle this heavy moving breaks things...like transmissions and drive shafts.
The pursuit is fun
All true Nowwhat, but your wasting your time with that clown. Dude, nice job on the viper ram! Getting that thing in the 10's is very impressive! Hats off to you sir!Well again I wish you success.
The pursuit is fun
TROLLAll true Nowwhat, but your wasting your time with that clown. Dude, nice job on the viper ram! Getting that thing in the 10's is very impressive! Hats off to you sir!
Very nice truck,
I'm itching to get my hands on this truck assuming the same about everyone else that ordered one. My goal is to find a balance between street performance and daily drivability with a set of wheels and tires while keeping the stock wheels and tires for the winter and off road trips. We won't know what fits over those massive breaks and what will and wont "look good" until we get our hands on them. I'm definitely not in a hurry to get this truck running 10s but if I can get it to the point with some bolt ons and a tune where it beats a stock trackhawk at a stop light it will put a smile on my face every time I am first in line at a light.
[/QUO
Massive brakes? 2 piston front brakes, single piston rears are massive? What color is the sky in your world? And no, we all already know 22s will look horrible, so probably perfect for you!
