Stripped threads on 2021 air cleaner box
BWU
Gretna NE
2021 TRX
Any ideas on how to repair stripped threads on 2021 air cleaner box? Metal screws going into plastic was not good idea. All our other vehicles use clips. I have never used anything other than a handheld nut driver to tighten or loosen these screws. (snug). Perhaps some sort of filler and re-tap them. A small plastic molly?
Anything you do will be temporary. I would pick up a used one on FB marketplace. They are all over FB for $100. Never use a driver or drill, always use hand tools on those bolts.
if you cannot remove, use a dremel to cut a slit in the bolt head and grab a flat head screw driver to unscrew.
Hand held nut driver with magnetic extension
Usually those threads are pretty durable, but maybe stripped from the factory assembly process.
You never know what happens during assembly. On my new 22, the air tube was never secured to the throttle body on the blower. It was just kinda pushed on a little bit.
