would like to see some real pictures first.....
100%would like to see some real pictures first.....
Where can i get that door kit???View attachment 145863This is the way if handicapped!
That's not a "kit". It's an ATC wheelchair conversion. The B pillar is removed and added to the two driver's side doors. Both doors are lifted as one piece with a pneumatic actuator mounted on the side of the back seat (partially blocks entrance to the rear of the truck).Where can i get that door kit???
www.atcmobility.com
Start around the 22 min mark - these guys took their TRX with a setup like this to BajaThat's not a "kit". It's an ATC wheelchair conversion. The B pillar is removed and added to the two driver's side doors. Both doors are lifted as one piece with a pneumatic actuator mounted on the side of the back seat (partially blocks entrance to the rear of the truck).
You can contact ATC and see what they charge to do the custom work.
Wheelchair Conversion Pricing | Trucks & SUVs
Our conversions are precision-engineered to deliver more than accessibility, they offer proven performance, safety, and long-term value.www.atcmobility.com
You may also want to update your "Current Ride". Dodge never made a TRX. The Ram TRX wasn't available in 2020 either.Where can i get that door kit???
Get RhO gears!I wouldn't mind having a lowered TRX, but then it would need taller gears, too.
That's something I'd like to have even with the OE 35" tires.
Umm, those are geared even lower than stock so that wouldn't help keep he rpms down.Get RhO gears!
It’s on my list for 2026
Incorrect, this customer, along with 99% of them, chose option 3 on the kit. This comes with double adjustable front and rear shocks which will give you WAY more settings / adjustability than the oem Bilsteins. Yes, you will loose the factory modes as you are removing that entire set up. This kit is currently on 2 of the fastest TRX's in the US and Australia.Looks like you replace the shocks so now you have only the one setting ?
Thanks for the feedback, we will let the customer that sent us the pics that you think so.pictures look like shit for 2025...just sayin...
We are not aware of anyone that has done it with Jscan. There is a company in Orlando, Fl currently working on a kit though to shut it off. Same thing done on the Trackhawks when guys switch to coil overs.I’m interested. I assume there are suspension messages and codes after removing the Bilsteins. Can I use my JScan to clean those up?
