Mine is very repeatable, almost like the TB doesn’t know how to meter the air in certain loads. This doesn’t happen nearly as bad on the big pulley for 93.I do not have any symptoms like that. The driving behavior is the same between auto and manual for me. The only time I have experienced something remotely similar to that is when I've been out of boost for a while with the IC temps below the dew point. I suspect some condensation from the IC bricks makes its way into the piston chamber. It's not super common, and I'm able to entirely avoid the situation if I keep my IC temps above the dew point.
Out of curiosity, what upper pulley size are you running, and did you get your Kong 2650 ported?
I’m running the 2.75 10% lower and did not port the 2650.
