New Reverse Light Kit Option Added to Website
Something else i didnt know i needed. these are sweet. going to order them. Question @Shifts_And_Grins - So as i understand the SSC1 Pro and the C1R both share the red and white output. Is the only difference the brightness in reverse, but also the fact the C1R lights up brighter red during braking whereas the SSC1 Pro is just red steady?
Comparing these two: https://www.shiftsandgrinsfabricati...true&sa=false&sbp=false&q=false&category_id=3
& https://www.shiftsandgrinsfabricati...true&sa=false&sbp=false&q=false&category_id=7
I hate this forum. :ROFLMAO:
I’m waiting for confirmation on white light output of the C1R. I didn’t notice a difference between them and the pro to the naked eye but the main difference is the brake light function of the C1R where the SSC1 PRO only has the red backlight and white reverse light. I hope that answered your question. If it didn't let me know and I'll try again.
Yea got it so the C1R flashes and gets brighter when brakes are applied in addition to the reverse light, the SSC1 Pro just remains dimly red, primary a reverse light.
I wouldn't say dimly red, they are a perfect match to the taillights and dots.
As if it wasn't confusing enough before, we added this kit too. I have filmed a video (Needs to be edited and posted which is not my strong suite) describing the differences between the kits but I'll do my best to type it here to make everything as clear as mud.
First you have to decide your light pods. Here are the options now:
SSC1 Sport- This is the least expensive and least popular of all of the options. We don't stock this kit but can drop ship them and they are typically in stock from Diode Dynamics. These lights have a red back light and a bright white main beam. They put out 1,449 lumens, 400 candela and 4 lux.
SSC1 Pro- This was the most popular item prior to releasing the C1R kit. We will see if the C1R kit overtakes it. We keep these in stock. We just received a large order of them, (Over $7,000 our cost in just lights). These lights have a red back light and bright white main beam. These lights put out 2,375 Lumens, 925 candela and 9 lux.
C1R- The last option is the C1R. I think this will rival the SSC1 Pro Lights in popularity due to the brake light function. We are drop shipping these until our stocking order comes in within the next week. We will keep these in stock just as we do the pro lights above. As far as output, I am waiting to get that from Diode Dynamics. It is not listed on the site. The HUGE plus of these lights is the ADDED BRAKE LIGHT. These lights have the same red back light that operates with the trucks tail lights, the same bright white light that operates with the trucks reverse lights and it has an added brake light that is a brighter red and will strobe upon initial application of the brake. This kit is only available in an auto operation format.I will describe this below.
Reverse Light Kit For Rear TRX Tow Hooks. You've already chosen if you want Sport, Pro or C1R. Now you have to decide if you want a super easy and fast install or the ability to manually turn on the white light (Sport and Pro Kits only).
Our Auto operation and C1R kits are a super quick and easy install. You plug a T harness into the 7 pin trailer harness behind your bumper and it has two leads with connectors coming off it. You route a lead to each pod light and plug it in. This kit works automatically with the trucks lights. The red back light comes on with the trucks tail lights. The bright white light comes on with the trucks reverse lights. With C1R kit, the brighter red lights come on with the trucks brake lights. The only disadvantage to the auto operation and C1R kits is it lacks the ability to manually turn on the bright white light.
With our other reverse light kit remaining, it comes with a full harness that runs the entire length of the truck. It connects to the auxiliary switches in the front and the trailer harness and light pods in the rear. This kit also work automatically but also allows you to wire the bright white light up to an auxiliary switch to manually control that light. This is a very popular kit and the best for people that want the ability to manually turn on the bright white lights. This kit is more time consuming to install and requires splicing into the auxiliary switch wires in front of the battery. This option is not currently available with the C1R lights (brake light options).
I hope that clears things up a little . I am always available on my cell phone (If I don't answer, leave a message and I'll call you back ASAP) 480-239-3148 Ryan
You can also message me here on the forum, email, or message through the website. Email is [email protected]
I went to website and tried to order, but it wouldn’t take the payment? Is there a problem website? Do I need to call?
Thanks
Thanks
I think they are awesome. I have the "auto" package but will likely change the harness at some point where I can also turn the lights on off an Aux switch.
So which item do we purchase? Are the SSC1 Pro lights the brightest? What is the auto Operation only kit? what is the difference witht the C1 and C1R lights for the hitch mount light???
Thanks
There isn't a problem I am aware of. We've been getting orders non stop. Feel free to call. 480-239-3148
I'd recommend reading through the post we made above that explains the differences and it should clear up most of your questions. If you did see it already and still have questions a phone call would probably be easiest. If I don't answer, I am probably on the other line and will call you back asap if you leave a message. 480-239-3148
The auto kits are really nice. We ran the auto kit on ours. I've installed the full kits on customers trucks though. The only time I have ever wanted them wired to my aux switch was when I was trying to get photos or video. Outside of that, I never ran into a need to manually turn them on but we all use our trucks differently and it is a nice feature if you need it. lol
