Someone posted this pic of a 27 TRX that's leaning to one side. That's a bit concerning.
If that’s the case, it should level out as the tank empties. I’d wait on that before jumping to any conclusions.'21 had this. They put the wrong spring in the left rear where the gas tank is. This might be the same thing.
I wonder how these are built, TRX/RHO roll down the production line together which I assume they would, TRX could get an RHO spring on the driver's side and the weight would cause that sag? who knows.If that’s the case, it should level out as the tank empties. I’d wait on that before jumping to any conclusions.
A few folks have experienced similar leaning on the RHO site. May want to check those posts to see if the root cause has been determined.
Though, if the factory installed the wrong spring, I would not be surprised.
Someone posted this pic of a 27 TRX that's leaning to one side. That's a bit concerning.View attachment 162761
Mine is level...... My 2021 was not.Curious if any of the 27 TRX owners have this sag, especially with a full tank.
Mixed severe ADHD with beloved ChatGPT re: Drivers side springs compression at rest and potential causation.
Inputed
2027 spring rate
Default Blackhawk shock setting
Will Hunting @ MIT
Potential 'Celebrity/YT Influencer' early production ownership.
Your Welcome!![]()
