Do you have pictures showing the bend in the brake line? I haven't installed any kits yet and was unaware of this requirement.I got my RB calipers and front rotors on. Very nice pieces. However I wasn't crazy about having to bend the brake line to keep it from rubbing tires. What's eveyone else's thoughts on this?
Also it triggers my ocd that the groove machined into rotors swoops foward instead of to the rear like every other rotor on the planet
Yeah let me get some tonight. The oem caliper has the brake line mounted on top of the caliper and the end of the line attached to caliper is a hard line that's L shaped. The RB caliper mounts the line on the side of caliper. The only way to give the line enough length is to mount the L facing up. When you install the wheel the tire hits the line. I had to bend the lines towards the engine to clear the tire. Stressing that hard line to bend it really concerns me. Because you are bending it where it's welded to the banjo bolt blockDo you have pictures showing the bend in the brake line? I haven't installed any kits yet and was unaware of this requirement.
OE line is directional (Left & right are different) and confined to a square “seat” in the caliper with a top oil inlet and can only rotate 90 deg.Yeah let me get some tonight. The oem caliper has the brake line mounted on top of the caliper and the end of the line attached to caliper is a hard line that's L shaped. The RB caliper mounts the line on the side of caliper. The only way to give the line enough length is to mount the L facing up. When you install the wheel the tire hits the line. I had to bend the lines towards the engine to clear the tire. Stressing that hard line to bend it really concerns me. Because you are bending it where it's welded to the banjo bolt block
ALL #2 GB orders will get shipped in about 2 weeks.
I got tracking Friday so I would check your email if you havnt.Any updates?
