HOT! First RAM TRX Owner on the Forum!
Like I said on FB, your camera is showing Anvil way better than other camera I've seen.
Hey can you take a picture near the rear mount for your running boards? I want to see if they moved the body mount around and if that's the reason we couldn't get AMP steps.
would have been nice for them to include lights on the ram bar!
I wonder if they did any pre-wiring like they did on the GEN1 Raptors for accessories...can't wait to see what light bar options start being installed on them.
awesome! Congratulations! I've also got a hydro one stuck in D status.. I am very curious if the Hydro will be as rare of a color as it appears based on the couple of hundred trucks built so far. only one or two of them are Hydro. Very excited for you!
For Rear Chase Bars, I'm debating on trying one of these out. Normally for ATV / UTVs but this or something similar may work nicely for off-road use.
  • 27 Pre-Programmed Modes
  • Programmable Running And 3 Auxiliary Triggers
  • Supports Running, Brake, Reverse, And Turn Signal
  • LED Colors: Red, White, Blue, Green And Amber
Tube Mount: https://justboltons.com/rigid-indus...-bar-rear-facing-light-bar-tube-mount-901801/
Surface Mount: https://justboltons.com/rigid-indus...r-rear-facing-light-bar-surface-mount-901802/
or BAJA's: https://justboltons.com/baja-designs-rtl-s-single-straight-30in-light-bar-103004/
My hydro moved to D1 recently, got a 1/24 “ship date”. My email from FCA said February. I would have expected blue to be very popular...
Hydro Blue is awesome and rare so far
Actually Gray but no matter what you call it , it looks great
Yes sir, the anvil gray does look great. The first poster in this thread recieved a hydro blue truck. I was making reference of his. I am a little partial because i have a hydro comming. (Sometime...) For some reason it does make it a little easier to wait for mine while I am seeing others getting theirs. I also sold my trackhawk this week. So, its getting real.
Little bit of frost this morning
  • IMG_1994.MOV
    7.8 MB
That thing is sick. Congratulations, will it fit in a standard height garage. Any chance are you letting us know how tall it is.
Now way will it fit in my three car garage nor would my 1500 Laramie
Based on the time left in production and the "set backs" they have had so far it is reasonable to assume they will only get around 4500 trucks built. We know 802 are going to be anvil which leaves 3500-4000 trucks for 6 colors. If they were split evenly that would be 6-700 of each color but clearly Black White and Granite are the 3 most popular regular colors which leaves silver blue and red to bring up the bottom with likely only a couple hundred max each. In the end for the 2021 model year it looks like it is going to be close as to whether black or anvil is the most common and it looks like a toss up between blue and red as for the least common unless Ram steps up production and starts producing 100 or more trucks per day
