FIRST BUILT VIN FOUND!
Made a quick change, and appears there are currently 141 Mules (5XXXXX) with build specs.
Great. If that number goes up then they are still making mules. Interesting that photos of new trucks are showing up but you can't pull build sheets for any other production vehicles. Very confusing why they would use beadlocks if they are "constrained."
Hopefully this truck shows up soon. Vin is in the high 900 range. Hopefully more will start popping up
Yeah, you wouldnt think that it would be too long before it had a window sticker generated for it.
Hmm, no build spec for any 9XX VIN still? Seems odd that it would make it to JB status before a build spec is online ?‍♂️. I wonder at what point it shows up in the process?
When did it go to D1?
Interesting my LE was placed by the dealer the same day it was released and mine isn’t even built yet. That Hydro Blue is looking really good. Had I known they were not building them in the order of orders placed I would’ve gone with a non LE in Blue.
Question for you guys. In the VIN above, the middle section is SRFU92MN
Mine from my dealer is SRFU96MN
Do your VIN's have 92MN or 96MN there? I'm wondering if my deal fat-fingered it when he emailed it to me.
Mine says 99MN
You are referring to the check digit. Everyone will have a unique one based on their total VIN #. Mine is X
Well this one now has the sticker for it available also.
It's the same one for #294 posted earlier, looks to be a FCA production evaluation vehicle.
There should be another one popping up in the 9XX range since someone of FB has the only reportedly customer truck in JB status... allegedly
I posted on the TRX Build Tracker thread that I was getting impatient just checking my window sticker link every morning and getting an empty page. I decided to write a quick script to check all the VIN's registered here in the hopes of finding any window sticker and still no luck. After searching a little online found a Reddit post that indicated the build sheet is available long before the window sticker in the build process so I added that to my script as well and still no luck for all 168 VIN's registered. I then decided to just set it to run ALL VIN's below 2000 and found 1!! What appears to be the first built TRX, or at least the first to show a build sheet.:D(y)
Its Granite Crystal, and has multiple items that were rumored in various places to be held up like Panoramic sunroof, carbon fiber, heads up display etc.
I will continue to monitor all VIN's and will post updates as they are available.
Build Sheet
If you don't have everyone's check VIN # won't you get mostly negative returns? Maybe we ask everyone to update thier VIN to the last 9 numbers?
I only need the last digits (and I left pad that with 0's), I wrote a function to calculate the check digit and create a valid 2021 RAM TRX VIN from just the provided digits on the tracker.
1C6-SRFU9#MN90XXXX
Where # is the calculated check digit and XXXX is the provided VIN
Thanks! I was worried I had been using the wrong VIN when checking for info! That check digit calculation looks like a pain in the ass!
91MN for me.
