slivoman
Did that already...no bueno. I at least felt the spring on the left side but it kept popping off. Going to try one more thing this weekend.Just use a long valve stem removal tool. Easy peesy. 2nd removal took under a min
When u push it in, are you angling it as you push? I cant remember which way but Potter's adaptive cruise install video explained it well.Did that already...no bueno. I at least felt the spring on the left side but it kept popping off. Going to try one more thing this weekend.
I found that i can’t get the passenger side till after i release the drivers side.Did that already...no bueno. I at least felt the spring on the left side but it kept popping off. Going to try one more thing this weekend.
Curious to hear from you in a few months. Mine was matte as well but the "finish" seems to have worn off and now its glossy.Got mine installed took me like 45min. I had no issues removing the airbag. Used a regular Allen wrench. Look and finish on the wheel is very nice. Highly recommend!
Ok so I lied, didn't get a chance until today. Found an old set of allens with flat ends not the ball ends and 4mm worked instantly driver side. Took about another 15 minutes and got the passenger side. Got the ACC switch installed and programmed....works great. Thx everyone.Thanks for all the tips, I will try again this weekend after I get back from MI
