Digital rear view mirror/3rd brake light/cable (complete conversion kit) FS
I have a 2023 with the Aux Camera option. I too am looking for the same solution. Is this 3rd break light kit and cable available for order from RAM? Anyone heard of an 3rd party making one? Put me on the list for one also.
you wouldnt happen to have another kit would you?
Does anyone have a video of the installation process?
@Dgreen thanks man for offering these at great prices. Just DM'd you my paypal address.
Been searching but can't seem to find an answer... If anyone knows, please chime in... I have a 2023 Level 1 with the regular mirror. There is a "mirror dimmer" button in the vehicle settings that also turns on the side mirror dimming. Does the regular mirror mode in the digital mirror have the auto dimming feature? I don't want to lose the side mirror functionality. Thanks in advance.
these are the settings I know of to change with AlfaOBD
LIN and Misc-CRVMM Present to NO
CBC Config I/O Usage-RVDM Present to YES
Just got in 3 more kits guys! Pm me if you want one! Same day shipping!
Slightly off topic but also slightly on topic...do ya'll know any way to modify the digital mirror to accept input from a trailer cam?
Not without physically switching the connection between the two.
You can use the dual input digital mirror from the HD Rams that has a dedicated tow mode camera input.
OK, that makes sense. So I'd get a dual input digital mirror from an HD RAM, and then run an additional wire from that mirror to the trailer cam? Running wires aside, does that dual input mirror swap in easily?
FYI, my car came with the normal (non-HD) digital rearview from factory. Apologies if my questions are novice.
Thanks, guys.
Thanks, guys.
the physical swap of the mirror is not hard at all. You will spend more time running the cables(especially if you have the pano sunroof).
Basically, yes. For the tow mode camera cable, you have to make sure to use RG58 coax cable, and about 70’ is the max before the image starts to get flaky.
Thanks guys. This is helpful info.
Just got a complete kit in. If anyone wants it hit me up!
you don't modify your mirror you get a mirror from a newer 2500 or 3500 that has the 2nd input
this might have actually solved my issue with running a bed rack and RTT on it and losing the rearview function because the RTT blocks it. i could route the trailer on at the back of the bed rack and still keep the original rearview for when i dont have the RTT on. brilliant lol
Hi, does anyone know if a 2022 2500 Longhorn rear view mirror is compatible with the CHMSL in our trucks? Have a friend who wants to retrofit and found one a couple blocks at a local scrap yard..any info is appreciated. Thank you!
