Dead battery after 8 days?
Tazer doesn’t plug into the OBD II port.
https://www.zautomotive.com/zpu/instructions/2019-Ram-Bypass-Install.pdf seems to disagree with you.
The only reason the Tazer needs that Y connector is to bypass the security gateway and get directly onto the canbus.
The rest of the cabling (power, ground etc) is the same source.
You can always plug your own security gateway bypass in and plug it directly into the OBDII port FWIW (which Zautomotive also mention in a separate guide - https://zautomotive.com/zpu/instructions/RAMGCSCWBypass.pdf )
TLDR - if you have a Tazer and followed any of their instructions, it's drawing power from the same source as the OBDII port - unswitched and directly to the battery. They're also well known (posts across many Stellantis vehicle forums) to cause similar battery drain issues that the OP mentioned.
Thanks for clarifying. To the layman (me) what could have changed that all of a sudden caused battery draw? I take it these things aren't one off mishaps
All I said was the Tazer doesn’t plug into the OBD II port and it doesn’t. Where it draws power from is irrelevant as if it is up correctly, it will not draw any power when the truck is off.
You're 100% dependent on the engineers at Zautomotive that wrote the software not making any mistakes/incorrect assumptions in their logic. If any were made, things like this can happen. Best advice would be keep it as up to date as possible (giving them a huge benefit of the doubt that they aren't adding additional bugs and only fixing prior issues) and don't leave it plugged in for extended periods where you're not driving the truck.
I went out to my truck today and the battery was dead, as in I had to use the key blade to open the door and jump start it. Battery voltage was almost immediately back up to 14v. I took it for a 5-7 mile loop and voltage was hovering around 13.8-9 during that time. I turned off the engine and locked it, got back in and in ignition on (engine off), voltage was 12.3v. Didn’t restart it, kinda just hoping it’ll start up tomorrow. Ordering a portable jump starter tonight - any recs?
A little back story: the truck hasn’t gotten a long drive since 12/31. Drove 5 miles last week and parked up since then. In terms of electronics, my truck has a Valentine V1 non hard wired (dash outlet doesn’t seem to go to sleep?), and a Tazer DT installed.
I hesitate to say it’s the Tazer since I’ve had it on for about 8 months without this battery drain problem. Temps don’t get below freezing here so I’m sure it’s not that. Could it possibly be the V1?
I don’t know much about electronics in this truck but I know a lot of y’all do. Any insight is appreciated
ISSUE: I went to get something out of my TRX last night and the dome light didn't come on when I opened the door. Doesn't respond to key FOB lock/unlock and definitely doesn't start. It sat in garage for about a week.
FACTS: I keep my radar detector and camera plugged via a "Y" connector into the cigarette lighter port on the top of dash. It has always shut-down after a short period of time, so never a battery concern. Headlights definitely on "Auto," so they weren't on. Not sure if it has something to do with dual dials for dome and dashboard brightness. Spoke to Ravelco installers and they assured me there is no way their device could have cause battery drain.
QUESTIONS: Any troubleshooting ideas re: drain source once I jump it with my wife's vehicle? Also, any suggestions how far or how long I should drive it to get battery back in sustainable shape? Finally, what is that measure?
I don't know much about vehicles other than how to drive fast, so TIA.
Basically same exact thing happened to me. I don’t know what caused it, it hasn’t been low since then. I drove around 15-20 minutes with the battery voltage meter up in the instrument cluster. Once it got up to ~14 and stayed there I parked up.
I’m trying to remember the algorithm for the alternators.
But if you put on the windshield wipers, it Max’s the alternator pwm signal for max output but uses the least power, so will charge the battery the fastest.
There are other things like rear window defroster, and other things that also tell the alternator to max output. But those use a lot of juice.
I'd also consider it's just shit battery quality. Our 2021 4Runner's battery died this week. Won't charge above 7V... OEM battery quality is probably the worst I've ever seen.
Good info, thanks. I'm leaning toward sh#t battery. Jumped it, drove it around 10 mins, parked it when it was stable around 14.1. On restart ~15 mins later, it just barely turned over. Just did a 30 min+ honey do run for the wife. It's hanging in high 13's. Will restart again in a bit . . . and may run wipers if Google doesn't uncover that it's fake news . . . the hazing of a newb forum member. ;)
Son just graduated UTI's Mercedes Tech program in Dallas. He added that the change from warm weather to the teens here in HTX could have been a variable.
TBD. Thanks again!
Cold weather kills batteries for sure.
The BCM has an algorithm in it for under hood temp, outside temp, and then there is a sensor around the hot cable that goes from the alternator to the battery: that measures the power being made vs what is requested by the bcm via the pwm signal.
If it is low or high it will adjust.
But if you have been in higher temps and it’s been learning that norm and then the battery starts acting different under cold temps, it can throw things off.
It’s also more likely just a bad battery.
TBD. Thanks again!
Never hurts to have a battery charger. They aren’t very expensive and much better to slow charge a fully discharged battery overnight
My battery kept dying after about 1500 miles. Dealer replaced under warranty and said there had been a bad batch. New battery has been good so far, just about to tick over 8000 miles and no issues.
At least no ones having the battery problems this guys probably having. Imagine the electrical mess this is:
We have at least one somewhere in our garages. Will check if it's a problem again tomorrow. If so, then NW Dodge appointment Monday for warranty replacement.
Related to dead battery issue: As my wife's SUV was charging my TRX, my odometer rolled forward--from 10,3XX to 10,4XX. I was parked in my garage and the engine was obviously not running. WTF? I was too slow to get my phone to video it, but I'm certain about what I saw.
Will check for other threads on subject, but thought I'd mention here since it was tied to the dead battery.
F-ing with odometers is a crime and a roll-forward means my warranties end earlier, so no bueno. TBD.
I think there is a thread on the odometer roll forward.
Apparently our odometers roll forward to
The current mileage when the trucks start. So it didn’t add anything.
A battery won't charge (other than getting a surface charge, as seen on a Volt meter) in 15 minutes.
My battery also dies after a week of sitting. My electrical mods:
  • IGLA
  • Compustar T13
  • Drone Mobile
  • TazerDT (unmarried. only for amber DRL, and auto mirror fold)
  • Uniden R7 (mirror tap)
