Hello guys!
I placed an order for a 2023 TRX. I live in miami and the order was placed in Granger Motors, around 1,500 miles away. One condition they asked was to fly there and pick it up in person. So, I have two options, drive it all the way back to miami or contract a transportation company.
My concern is the “break-in engine process”.
As you all know you need to drive it the first 500 miles with a lot of requirements:
0 to 100 miles (0 to 161 km):
300 to 500 miles (483 to 805 km):
For the first 1,500 miles (2,414 km):
• Do not participate in track events, sport driving schools, or similar activities. (I’m fine).
So, what do you think, should I perform the breakin engine on my way back or should I pay to bring it back home with a transportation company (which one do you recommend) and do the breakin at home with less stress and save the paint from rock chips?
Thank you for your advices
- Do not allow the engine to operate at idle for an extended period of time. (This is easy)
- Press the accelerator pedal slowly and not more than halfway to avoid rapid acceleration. (Less easy if you take a high speed way)
- Avoid aggressive braking. (This is fine)
- Drive with the engine speed below
3,500 RPM. (It’s ok) - Maintain vehicle speed below 55 mph
(88 km/h) and observe local speed limits. (This is a problem, 55mph is hard to archive in highway)
- Press the accelerator pedal slowly and not more than halfway to avoid rapid acceleration in lower gears (FIRST to THIRD gears). Ok
- Avoid aggressive braking. Ok
5,000 RPM. Ok - Maintain vehicle speed below 70 mph
(112 km/h) and observe local speed limits. (This is more reasonable )
- • Exercise the full engine RPM range, shifting manually (paddles or gear shift) at higher RPMs when possible. (and here start the fun)
- Do not perform sustained operation with the accelerator pedal at wide open throttle. (Ok)
- Maintain vehicle speed below 85 mph
(136 km/h) and observe local speed limits. Ok
