Downsizing the factory wheel is not a good idea especially for TRX, just like other trucks and SUV, it has a beefy (big, heavy & bulky) hub spindle, wheel bearing, and brake proportional to it load and HP - Mechanical is NOT Electronic.Still nothing for 17's?
Thank you for remembering us, usually aftermarket wheels are more forgiving than stock so I believe it shall fit although a template test is still recommended before ordering.I worked with the guys at Racing Brake a long time ago when I was at Infiniti and the design of the rotors they came out with was outstanding.
Will the brake kit work on Volk TE37XT 18’s? I’m here in SoCal and would love to get a kit if it works with the wheels.
can you put me down for a complete car kit in red pleaseYes, that option has been added to the website. I edited the main post to reflect the change. You would need to select the "Front Caliper Kit Only" option which comes with the calipers, pads, adaptors, and front rotors. The price would be $2550.00 after the discount has been applied. You can save an additional 10% if you order the complete "Car Kit" that includes the rear rotors as well.
What's the offset of the wheels that you have? In the picture I posted, it looks like the template is near the front lip where the spokes connect to the barrel. I imagine if you have a more negative offset wheel, then you should have greater clearance.
From my understanding, there is no plan to come out with a rear caliper setup due to the integrated electronic parking brake. Warren briefly touched upon in this post:
HOT! - RB Performance Brakes is a Supporting Vendor of RAM-TRX.com!
The OE caliper wt just got updated - It's 26 lbs loaded with pads (wear is neglected) so there is a solid wt saving of 15 lbs per caliper which is very ssubstantial. Our caliper pistons are made of stainless steel (machined from a bar stock) which has much lower heat conductivity than carbon...www.ram-trx.com
I, too, am on factory beadlocks. I just assumed they were the same fitment as the non-beadlock OEs. I look forward to your template check results. I'm currently without the truck for another 8 days or so.They’re a 0 offset, but I feel like they sit a little closer to the barrel of the wheel. Have to work a late shift tonight so won’t be able to check with the template until tomorrow evening.
Makes sense I guess for the rear with the electronic parking brake, but if the other companies make a rear kit I wonder if it messes with that function![]()
Is unpainted (but ready for paint upon delivery) an option? @Warren-RB
I’d color match the rear calipers with the fronts so rather have it all done once and not try to have to match shades
Front brake kit for 17" wheels is up - No rear kit at this time.I'm not up to date with the 17" kit progress, perhaps @Warren-RB can shed some light for us. I know that there were a few stipulations that had to of been met for the 17" kit to be a possibility. One of the major challenges was whether or not the smaller rotor would be compatible with the rear factory caliper that has the electronic parking brake. I'm not sure how the initial testing panned out.
