- Joined
- Apr 7, 2025
- Messages
- 37
- Gallery
- 5
- Reaction score
- 100
- Location
- Gainesville, VA
- Current Ride
- F350
Just called AMP. They said that is incorrect. Those are not compatible.
Don’t know what to tell you but they work perfectly fine. It’s the same color wires you tap into on gray plug under dash left of steering column. All 4 doors lower steps when I open each door and all 4!doors raise steps when I close each door.Just called AMP. They said that is incorrect. Those are not compatible.
I took a chance doing it. Not telling you to do it. Just sharing what I did.Don’t know what to tell you but they work perfectly fine. It’s the same color wires you tap into on gray plug under dash left of steering column. All 4 doors lower steps when I open each door and all 4!doors raise steps when I close each door.
Also if you called Real Truck you probably talked to a sales person. If it doesn’t have the year for the part # they are going to say not compatible. They may not have had a chance to try them on a 2027.I took a chance doing it. Not telling you to do it. Just sharing what I did.
When I first started my order, I didn’t realize they were not an option on the build sheet. A dealer I spoke with said RAM stopped offering them because too many were getting destroyed.
Then, he said their dealership doesn’t install the Mopar steps anymore and use only AMP. I don’t know the validity of that, btw.
It’s my understanding that they are both similar with the exception of the uconnect connectability and the AMP deploys a little faster and has lights.
IMHO, I don’t need to control them with my app or fob so I’m happy to go with AMP.
Magnetic door sensors ?Ram never offered power running boards for the TRX as an option, so that dealer is full of shit.
Installing aftermaket steps instead of the Mopar steps is just stupid for a Ram dealership. If your Ram dealer installs Mopar steps, they will be covered under your bumper-to-bumper warranty.
If the AMP steps you're considering plug into the OBD port, I would avoid them. Too much Micky Mouse shit with magnetic door sensors, needing an OBD splitter, etc. If they plug into the CAN bus, they are worth considering.
Overall, I prefer the Mopar boards because I think they look better, can be activated in the UConnect screen, and AMP boards drop down too low. (4" lower than the Mopar steps.)
That is great info! I’m definitely getting a set when my truck gets in. Thanks!Magnetic door sensors ?
I’ve used AMP steps numerous times but I don’t ever use their lights, I just seal the leads and tie them off.Yeah, never mind. I was thinking of those goofy ass lights that attach to the pinch seam.
You installed the amp steps on your 27 TRX? If so how was install? I recently purchased a set and I’m looking forward to putting them on in the fall once the truck comes in.I just installed them
Install was easy, exactly per the instructions.You installed the amp steps on your 27 TRX? If so how was install? I recently purchased a set and I’m looking forward to putting them on in the fall once the truck comes in.
Did yours come with a module that you have to plug into the body control module?Don’t know what to tell you but they work perfectly fine. It’s the same color wires you tap into on gray plug under dash left of steering column. All 4 doors lower steps when I open each door and all 4!doors raise steps when I close each door.
Here are the instructions and like ChemLab stated Real Truck probably hasn’t verified fitment. I took a chance since wire colors and locations matched the instructions.Did yours come with a module that you have to plug into the body control module?
Ok I go it now. These are very different from the mopar ones that come with a module that you have to connect to the BCM.Here are the instructions and like ChemLab stated Real Truck probably hasn’t verified fitment. I took a chance since wire colors and locations matched the instructions.
Question for you if you know - if the Amp controller is connecting to the OBD-II port (ostensibly just to read the CAN bus to detect door open/close), then why do they have you tapping two wires with the Posi-locks? Assuming those wires are the door sense wires.Here are the instructions and like ChemLab stated Real Truck probably hasn’t verified fitment. I took a chance since wire colors and locations matched the instructions.
