Hey everyone, looking for some help from anyone who has completed the Uconnect 4 → Uconnect 5 / digital cluster conversion on a 2021 TRX.
Here’s my setup:
I paid $550 for the physical installation. Everything powers up and the Uconnect 5 screen and digital cluster are installed and functioning, but I currently have three main issues:
I first spoke with American Radio in Roswell, GA, but they told me they could not perform the Mopar recalibration/VIN coding needed for this retrofit.
I then took the truck to a Dodge/Ram shop/dealer with wiTECH. wiTECH does recognize both the RADIO and CVPM in the network topology. The RADIO shows orange and the CVPM shows yellow.
They attempted the camera calibration. From what I was told, they were able to get the front and rear cameras through calibration, but the left and right/mirror cameras would not complete. They also said the radio does not seem to be communicating properly with the rest of the system.
They were looking for something they could change/add through the factory configuration or sales codes, but because the truck is a 2021 VIN with newer 2023-style electronics retrofitted, they haven’t been able to get everything communicating correctly through normal wiTECH programming.
They quoted me another $450 for programming/calibration, but at this point it doesn’t look like they know how to finish the retrofit.
What I’m trying to determine is whether this sounds like:
I do not want the dealer to restore the truck completely back to its original 2021 configuration or blindly flash modules, because I don’t want the retrofit settings overwritten.
The fact that I’m missing both navigation AND album art in the cluster makes me especially curious about the radio-to-cluster Ethernet/CAN connection. And since the front/rear cameras will calibrate but the two mirror cameras won’t, I’m wondering if that points toward configuration or wiring rather than the CVPM itself.
The radio is T25 software, so from what I’ve researched it should be the correct generation rather than one of the newer incompatible U-series radios.
Has anyone with a 2021 TRX successfully completed this exact setup? If so, what did you have to change/program to get:
Also, if anyone knows exactly which AlfaOBD/CDA settings, CAN interface, harness connections, or Ethernet wiring I should verify, I would really appreciate it.
I’m in the Roswell/Atlanta, GA area, so recommendations for someone locally who has actually done this retrofit would also be extremely helpful.
Here’s my setup:
- 2021 Ram TRX
- Uconnect 5 12” Display — 68526598AC
- Uconnect 5 Radio Module — 68583503AE
- Radio software — T25
- Newer CVPM / 360 Camera Module — 56029968AF
- Digital Gauge Cluster — 68510283AH
- TRX Digital Cluster Mask — 68620863AA
- UC4 → UC5 conversion harness
- Truck originally came with factory 360° cameras
- Factory 360 cameras are not working correctly
- Navigation/map does not display in the digital cluster
- Album art does not display in the digital cluster
- UC4 → UC5 conversion harness / pinning issue
- CAN-bus communication/configuration issue
- Missing or incorrect CAN interface
- Missing/incorrect 2-pin Ethernet connection between the UC5 radio and digital cluster
- BCM configuration/model-year issue
- CVPM configuration issue
- Something specific that needs to be changed using AlfaOBD/CDA rather than wiTECH
- Or another part/configuration I’m missing
- all four cameras recognized
- 360° surround view calibrated
- navigation in the digital cluster
- album art in the digital cluster
