I run 5% all the way around and 30% on the front. Here are a couple pics in the sun for reference. Nice thing is I rarely wear sunglasses in the truck with this setup!
looks great. unfortunately my night time early morning time vision is not as good as it used to be when I was in my 20's . So there is no way I could do that.
Discovered a geyser in Atlanta.
Take it someone lost control showing off their striker!
New OE tires on black beadlock rims with powder coated red beauty ring.
JLAudio Stealth box TW3 10s with JLAudio VXi 1000/1 amp.
Sounds amazing with the HK system.
Question for all the guys who have added subs…where did you all mount your bass knob. I’m struggling to find a spot.
Also finished up some custom center caps for my Vossen rims. These are the modular center caps. The come apart in 3 pieces, makes it easy to customize them.
I initially put it under the power pedal switch but I kept hitting it with my knee on the way in and out.
So I moved it to next to the headlight switch which I am much happier with. Bought an extra trim piece so I can revert to stock if need be.
My amp step override switch is under my pedal switch. Wouldn’t happen the part number for that trim piece where you have it now?
Color matched flairs look good! Gonna have to bite the bullet
If you shop around you can find a good price. It’s a lot of prep work because everything needs to be sanded. 12 pieces for the fenders another 4 for front. I had quotes over 4K. Found a guy that did them for 2k. Then of course PPF and ceramic 30 days later.
if you already have the leather wrapped one just go to your truck and check and see if the part # is on it(just make sure you are not looking at the part # for the headlight switch. they pop off really easily.
Changed front passenger window due to a rock chip.
You should participate in totm this month with the first picture
Ive been thinkin about it haha. That was the 1 i was gunna use too since an actual photographer took it! I may take the month off tho and hopefully get that coveted 3rd W next month
