Only downside to the Stealthfighter that I see is upside down oil cooler (which should be addressed in the next six months or so) in the end not draining an oil cooler shouldn’t be the end of the world.
Design on the winch mount is pretty good. Easy access to wiring and on/off switch through driver side wheel well.
I have Rigid 360 4” fog lights in mine.
On the rear… I used Rigid Chase Pods. (They are 2”x7”. Operate as red when the truck is on, brighter red when braking or using turn signals, they have a bright white reverse light, and I have the strobe function (Red) wired to a switch.
The pictures I see on the ADD website looks like there are rear cutouts in the back for square lights. My DD looks like it would be perfect there and have about the same functionality as yours.
I wonder if my M&R 40" light bar would work up front.
Your diode lights will fit perfectly. The light mount sits at the center of a 2”x7” opening. So anything in that range will work. I can tell you, the left side (near the step) makes the install awkward if you are really filling up that space. A 2”x2” square pod is easy peasy. If you’re lighting crazy like me, but don’t want to go the rigid route, I would put the diode CR1s there and add the turn signal/brake functionality to the pods.
M&R bar is a straight bar if I’m not mistaken… you would need to pick up a curved bar.
I did a few things so far. I added red inserts on the TRX letters. I removed the RAM badging from the driver's and passenger's doors and added TRX badging and T-rex heads. I added the Taser DT for the amber DRL's, and I applied the black hood graphic with the red TRX emblem on the hood. Next I'll be adding the red tow hooks and the red TRX widow banner.
I have the same hood graphic sitting in the garage, I’m not sure I want to try applying it myself though. Yours confirms that I want to do it though!
Where did you purchase the TRX bedside decals?
I installed a Barton Shifter. Had to make a few adjustments but looks and works GREAT!!!
@TonkaToy - Nice find!
The Barton shifter looks awesome! Great recommendation. I went with the pistol grip which includes a few minor modifications, but very similar to the Barton ball shifter directions you described. Looks great with the black interior and white truck.
That does look AWESOME!!!!
Reactions: DMR
I purchased the black hood graphic with the red TRX overlay, and the red TRX letter inserts from Underground Graphics in Hpuston. You have to call them for any TRX lettering. Their number is 713-783-4739. Call and ask for Michelle Lilly. Tell them Billy Shelton referred you so they will know exactly what you're looking for.
