The story Toyota gave consumers about “dirty” engine builds in the US has been proven false. They have cleaned that facility & engines are still eating their crankshaft bearings. So, they went to a stronger crankshaft bearing material & it has helped, but not solved the “problem”.
A professional engine builder decided to tear down his personal Tundra engine after it started making noise. He did find lots of debris, as expected, but the passages feeding the crank bearings were relatively clear, but tiny! Why tiny? Because Toyota specifies 0-W20 oil, for fuel economy.
It appears that oil is simply too thin for the duty cycles that many owners require.
So why were the hybrids, built in Japan, impacted to a much lesser degree? Well, those engines have electric motor assist, meaning the ICE bearings see lower loads.
So why are Sequoias & GX-550 not as heavily impacted? Well, how often are those vehicles subjected to the loads seen by their pickup truck counterparts? Not as often.
You can’t run the necessary 0-W40 oil due to the narrow oil feeds. So, it’s a mess that will require an engine redesign & re-certification.
