The NEW MO-041…take a dump in a box and mark it “SRT”…
I just had the exact same experience with the filter and posted a thread on it because I wasn’t sure it was legitimate. I couldn’t believe it was actually legitimate and I ended up using it but it’ll be the last time. Thanks for opening them up and providing the comparison!
What is a good source for purchasing the Wix filter from? Online or local?
I bought it in store at O'Reilly. They will price match too.
I wanted to revive this quickly because I had a few questions. Plus I know a few guys here also have Vipers.
TRX owners were using the SRT Viper 041 as an upgrade to the 899 is this correct? But now the 041 is no different than the 899. An upgrade would be Wix 57063?
Viper were using 041 but that is just for the new Gen IV/V not the Gen II (96 GTS) the Viper logo (not a sticker and it is white) says 05037836AB. Is there any knowledge if those filters were changed? I have seen some available online like Amazon and Mopar online sites but I do not want to down grade a filter. Are there any upgrades to that filter? Should I check with Wix and see what they offer? I figured I would see if any fellow Viper owners had some insight plus ask this forums oil gurus.
These are suppose to be the go to upgrade.
MicroPure XR® Engine Oil Filter - Replaces AC Delco PF26, Motorcraft FL-820S, Mopar MO-899
OMG!!!!!!
A small amount of research would address this. but for those that wont here it is. There are NO differences between 5038041AA/AB VS 4884899AC accept two things. The appearance (who cares) AND THE BYPASS SPRING! The one thing you did not show in the pictures. I am not sure you would see a difference even if you did show it.
The bypass spring in the 5038041AA and AB variant are lighter. This allows the filter to go into bypass sooner. This prevents the engine from becoming oil starved under heavy load. Nearly ALL oil filters have some bypass ability to prevent oil starvation. Yes you are dumping "dirty" oil into the system but your not starving the system.
The point of the thread is that there used to be a substantial difference between the MO-041 and MO-899. A completely different design, 20% more filter media and a much thicker canister. There was at least something arguably worth paying more for.
That filter…the old, Wix-based MO-041 could run a lower bypass PSI setting without increasing its tendency to actually bypass in use, because it was less restrictive in the first place. It wasn’t and isn’t a case of simply sticking a lighter spring into the same filter and getting “more flow”. All other things equal, doing that only guarantees it bypasses more, and filters less of the oil already being forced through it by a positive displacement pump with a very high pressure relief setting.
A filter in bypass is a rare and undesirable condition, not a design feature.
