Squadron 2.0 OUT NOW !!!!
BajaDesigns
San Marcos, CA
The Best Just Got Better​
Built on the legacy of our most trusted compact light, the all-new Squadron 2.0 has been completely redesigned from the inside out. Featuring a modern design and next-generation optics, the Squadron 2.0 delivers increased output with refined beam patterns that provide greater distance and increased pattern width while minimizing wasted light spill. The result is even better light exactly where it’s needed, whether you’re driving tight trails, open desert, or open roads. Every detail has been engineered to enhance durability, performance, and consistency, raising the standard for a small 3-inch auxiliary LED light while maintaining the proven reliability the Squadron name is known for. BUY NOW!
  • Improved performance – Pro 41%/ Sport 35% performance increase over Squadron 1.0​
  • All new color selectable backlight – industry-leading 9-selectable backlight colors in a 3” light package​
  • Improved uService functionality includes new clip-in reflectors that won’t fall out, and a new lens gasket improves sealing out the elements, reducing pinched o-rings/sealing failures​
  • 4-pin Deutsch-style connectors are standard on the wire harness​
  • Redesigned universal bracket allows for increased vertical light adjustment​
  • Updated lens patterns/designs for increased performance​
  • Newly designed vehicle-specific kits (VSKs)​
The next generation of Baja Designs​
HIGH OUTPUT PERFORMANCE: The Squadron 2.0 Sport produces 3,200 lumens at 30W. Next-generation optics throw light farther and wider while minimizing wasted spill, delivering more usable illumination exactly where you need it.
For drivers demanding maximum output, the Squadron 2.0 Pro throws 5,921 lumens at 65W, a 41% increase in power over the previous generation. Both configurations operate on 12-36V systems and are available in harness and non-harness pair options.
COLOR SELECTABLE BACKLIGHT:
The Squadron 2.0 features an integrated 9-color selectable backlight. Drivers can toggle between red, green, blue, magenta, cyan, amber, yellow, pink, and white, all configurable through the included harness. Color settings are retained when the light is powered off, so your setup is always ready when you are.
IMPROVED uSERVICE FUNCTIONALITY:
Updated uService® components include clip-in reflectors that stay secure during lens swaps and a new gasket design that improves sealing and long-term protection from the elements. A rugged 4-pin Deutsch-style connector replaces the previous standard for enhanced durability.
Every detail has been upgraded while maintaining the proven reliability that defines Baja Designs.
CLEARVIEW OPTICAL CONTROL:
Features Baja Designs ClearView Optics with updated reflectors and lens designs for increased usable light, improved beam pattern efficiency, and reduced driver fatigue using Baja Designs’ exclusive 5000K daylight color temperature.
CONNECTORS TO HANDLE ABUSE: 4-pin Deutsch-style connectors are now standard on every wire harness — weatherproof, vibration-resistant, and rated for the kind of punishment that kills cheap connectors.
BUY NOW!
Squadron 2.0 Sport
Squadron 2.0 Pro
Squadron 2.0 Story​
Looking to get an order placed directly, reach out to [email protected] for Exclusive forum member specials.​
Best,
Brahian Herrera | Forum Sales & Support
Email: [email protected] | Phone: (760) 560-2252 Ext 201
