Secondary whining noise 2 when driving fast.
AtTrX22
TRX Noob
Florida
2022 Ram 1500 TRX
Hey guys I’m having trouble and haven’t been lucky at the shops. Ever since I got my fuel induction/carbon build up in the engine cleaned out, two days later I’ve had this whining sound going off whenever I’m driving fast. It sounds sort of mechanically. I already took it to two places including the shop that’s been working on the normal maintenance. Both shops say this secondary whine noise is normal but it’s not. I never had this noise ever and my truck is at 50k miles. The dealership checked all my fluid and belts and the blower saying everything was good. I also had my transfer fluid, diff fluids and transmission fluid and plus belts and spark plugs changed way before this noise came about. The noise has been happening for the past month since that fuel induction/carbon buildup cleanup and recently I noticed my supercharger coolant was really low. I know I wasn’t paying attention to that fluid since hey you would think these shops will let you know about it and clearly didn’t. I’ve also had a check engine light twice saying it was a cylinder misfire both times. It disappeared the first time after they did the fuel induction cleanup then a week later happened again and it’ stayed for two days. The compression test was done as a response with the shop confirming everything was good and hasn’t had a check engine light since. No shop told me my supercharger coolant was low so I added a little more and the noise faded a little bit. The fluid hasn’t gone down at all since adding it yesterday but wondering if I should fill it closer to the MAX line? Do I have air in my coolant system? Should I just have a full flush of the coolant done? Or is the way I can just bleed out the air myself? And should I do an oil change just in case as well? Thanks
