Ripatuned new product!
Grey03svt
Indiana
Ripatuned Stage 1 Interchiller. Advertised as plug and play. Not cut, no chrimp, easy install, easy removal with no trace of it being installed.
Copied from Facebook
You may have remembered my post about big releases from Ripatuned in the last two quarters of 2022, well here is the second big one. I need to thank my head of sales Antonio for spearheading this project. He knocked it out of the park. Here are some pictures from design to reality.
Here is our Stage 1 Ripatuned TRX interchiller system, and in regular Ripatuned fashion, we went over the top. This system incorporates a full Plug and Play installation, no lines to cut and crimp, no real setup what so ever. We designed this to be a complete bolt on with no modifications needed to the vehicle. Our stage 1 kit incorporates a drag valve as well like most other stage two packages, and it is easily controlled by the in cabin AUX switches for those high speed runs or drag racing applications where maximum cooling is needed.
What does that mean for you? Easy and clean install, no chance of leaks and can be removed from the vehicle easily be sold if you ever sell the vehicle. You can revert back to stock without a trace and with no new parts to buy. Oem style crimped AC lines, pre cut to length.
Simply install this kit in line with the stock system and you are good to go in under an hour.
Look for our Trackhawk and Durango systems next, as they are currently in the development phase.
We will have final pricing shortly, as well as an intial group buy as always.
Ice cold IATs, all the time 🧊 🍻
#ripatuned
#ripatunedequipped
