Do we have any indication that cold case is no longer a good product?
No.
Im just saying for folks to look into things. Usually if a company doesn’t highlite the type of core being used, that’s because the core is just a generic core.
Plate bar… or advertising pressure drop, or bu ability etc.
I’ve run Ron Davis and theirs had pin hole leaks. Their customer service was lacking.
Stuff like mishimoto etc, Which I’d be willing to bet that this “Cold Case” radiator falls into the same catagory quality wise: is a bit of you get what you pay for. Or rather o should say, maybe you get a little less than you pay for.
You are paying for a “competition grade” heat exchanger/radiator but are you getting it? Or are you getting a generic core that is just a bit thicker than stock. And you are getting the theoretical strength enhancement of not being a crimped radiator (is our trx a crimped radiator? Most oems are now a days)
But at the end of the day, for “$X” are you getting what you should for the money.
I have CBR performance radiator and oil coolers on my prerunner. The radiator cores are amazing, the thing is a thick momma jammma. However, it’s a custom company and if there is ever an issue, it’s a bit of a “there is a line, we will get it fixed when we get to your place”.
I think I would look at a company like pwr and their stuff. They said they will make a radiator if someone would come by so they could check clearances. Also a heat exchanger for the s/c and a better oil cooler core.
They have a lot of knowledge when it comes to vibrations and fitment. they are big enough to be able to test each piece made.
If koyo for instance made an oem fitment, I don’t know if it would be worth the headache of the swap out for a non crimped piece, but stock ish core size.
Speaking of which. When theu chopped my frame on my Colorado prerunner and I had to go aftermarket radiator, I had to do a lot of research both on radiator size and ability, but also cooling fans and fan tuning.
I found that oem equivalent replacement radiators would all essentially have the same length by height, but the core thicknesses would be different from company to company. Each of the production companies had their own generic core that they made their radiators from. And when you are dealing with a .8 inch thick core, a core that is 1 inch, or 1.1 inches thick is a massive “upgrade”
So another thing to look at is finding the core thicknesses on oem equivelant replacements and even though it will be a plastic end capped, crimped style radiator… some may be a thicker core with larger capacity tubes. A oem equivalent radiator that has 10-12% more efficient bu ability is better than a aluminum unknown quality with essentially the same bu core from a koyo, mishimoto, griffin or cold case.
Again, I’m not saying any of those are the same bu as stock, or have bad cores. I’m saying that some of the above named have sold product with crap cores in the past. I know nothing about their trx offering.
