So got a question on wiring. I want to wire the white light to fogs button and Amber to fuse tap 11. Since I’m a novice for electrical wanted to make sure things didn’t go sparkity spark when I did it.
So this is the stock fog connector
And the connector I bought is this one…
1- Which I believe is incorrect since they don’t connect and both appear to be the same (female I believe). So now I presume I need to buy an H11 foglight male harness instead like this one in the link below?
H11 male harness
And if that’s correct then to wire it…
2- Since the blue wire is ground on the fogs, and the H11 adapter has a black wire for ground then all 3 blue wires come together into the black wire of the adapter on each side
3- The brown is the positive wire for the white fogs so all 3 brown wires come together into the red wire of the adapter on each side
4- The male adapters can how be plugged into the oem female fog connections on both sides.
5- That then leaves yellow as the positive wire for amber backglow so all 3 yellow wires come together on each side, then find some wire extension to bring both sides (6 yellow wires total) together (maybe using one of the wires on the Y wiring harness that comes with the fogs) into the 1 red wire on fusetap 11?
6- In the end what’s leftover is the 2 grounding cables since the grounds are connected to the fog adapter and 1 of the 2 long Y connector wires since it’s just needed for amber backglow?
7- As for then wiring the light bar the black ground goes to a grounding point and red goes to whichever Aux I want to use which is easy enough
8- and then to have the lightbar amber backglow running with the fogs backglow, I would connect the blue wire from the light bar also into the wire that has the 6 incoming yellow wires of the fogs all together in one bundle to the one red wire on fusetap 11?
9- keep the oem fuse on fusetap 11?
I numbered some of my sections up there so that if I’m doing something blatantly wrong it’ll be easier to name a step to tell me where I’m wrong.
Thanks for all the help guys.
@DIABLOPOWER702
