I'm the original owner of my 2022 loaded TRX, virtually issue free so far.
I hadn't driven the truck for a couple weeks and encountered an issue today. The battery is fresh, voltage is fine, and the truck stays on a Battery Tender. I started it and as always changed the Drive Mode to "Custom". My "Custom" setting it basically "Sport" mode but with Normal steering. Driving the truck, none of the Sport or Custom features were there, it had normal suspension, no delayed shifting, etc... so it appeared my "Custom" setting went away.
I went into the Drive Mode setting on the center screen to reprogram my desired Custom settings, however it will not allow me to modify Custom or any mode. When it first pops into Auto mode and I press the Custom button and then press "Custom setup" at the bottom, the screen goes back into Auto mode and Auto mode setup. Same with every mode, trying to modify any mode after a few seconds, the screen goes right back into Auto mode as if I'm trying to modify Auto more.
I rebooted the center screen 2x by holding the volume button in for ~10 seconds until the screen reboots. No help.
Any ideas ?
thanks...
Any ideas ?
thanks...
