No. I can't find it on their website, either.Any pictures from Hellwig on the u bolt setup?
you currently have a 1.5" rake? I had exactly 1" rake prior to the install. I do have a retrax which might have sat it down a bit. Its visibly noticeable, even a buddy came by (he has a TRX) and asked if I had anything in the bed since the truck looked level.I didn't measure but I definitely have the factory rake which I'm going to put a 1.5" level kit on to reduce. 1/2" shouldn't be visible enough to decern a change in the rake.
A sway bar will not change vehicle height on flat ground. Try disconnecting the bar or changing the bar angle, it will not affect height.I have my bar leveled and the rear fender height measures aprox 1/2" lower than it was prior to the install. The truck looks level now but I actually prefer the rake on this truck.
Are you guys getting similar results? I could lengthen my end links to get it back to stock height I believe, but then the bar would not be level. Thoughts? Thanks
That’s what I thought too but once it was installed the fender height measurement changed. I measured exactly the same way and in the same spot in my garage.A sway bar will not change vehicle height on flat ground. Try disconnecting the bar or changing the bar angle, it will not affect height.
you will really like the improvement!Following. About to start the install on my 22. Probably just get the 4 holes drilled today, throw some paint on them, and get to everything else tomorrow afternoon. I'll add another post once it's in with my thoughts!
Installed. Little bit of a pain, but not too bad. I ended up making spacer brackets first - 0.52" thick. Then mounted the end links and got them perfectly even L/R. Hung the bar (bolts semi-tight). Lined everything up and then measured where I wanted to drill the holes. Just got back from a test drive and everything is quiet and feels solid - even just bombing around the industrial park my shop is located in, I can already feel it. Looking forward to the highway drive home haha.you will really like the improvement!
if you don't mind, can you take before and after fender height measurements AND the length of your end links you set them at (just let me know how you measured so I can compare).
Thanks!
great response/info. Thank you!Installed. Little bit of a pain, but not too bad. I ended up making spacer brackets first - 0.52" thick. Then mounted the end links and got them perfectly even L/R. Hung the bar (bolts semi-tight). Lined everything up and then measured where I wanted to drill the holes. Just got back from a test drive and everything is quiet and feels solid - even just bombing around the industrial park my shop is located in, I can already feel it. Looking forward to the highway drive home haha.
Measurements:
End links (bolt center to center): 14.75" - I might tweak this a little.
I couldn't safely get the rear wheels off the ground to make the axle fully droop, but definitely close. And the bar wasn't even close to touching the lower spring perch or anything it shouldn't touch. I'll get it on a lift in the near future just to be sure.
Ride height before install (stock level 2, without rambar or bed mounted tire carrier, gas tank 3/4 full, spare tire, and tires at 35-36psi). The ground was fairly "level"
FL: 40.0"
FR: 39.8"
RL: 41.15"
RR: 41.0"
After: Honestly, any change was nominal. Maybe 1/8" at the MOST. And even though I did go on a test drive after messing around with the floor jack, any height difference is probably still just the suspension re-settling.
However, I keep reading/hearing about holes needing to be drilled. I am assuming these are for the brackets that mount the swaybar to the rear axle itself. Is that correct?
1/2 inch spacers between the mounts and axle brackets is a good idea tooExcuse my ignorance for asking this, but I haven't found a full install video for a 22 yet. If one exists and you can post it in this reply that would be fantastic.
I really want to install a Hellwig on my truck. For a truck its size, it drives great, but I think I would enjoy less lean/roll around corners. With that being said, I feel I understand how to install it. However, I keep reading/hearing about holes needing to be drilled. I am assuming these are for the brackets that mount the swaybar to the rear axle itself. Is that correct?
Perfect, thank you!Yes, that is correct.
Thanks for the advice. I will make sure I do that as well.1/2 inch spacers between the mounts and axle brackets is a good idea too
What’s reasoning for the spacer?1/2 inch spacers between the mounts and axle brackets is a good idea too
Giving the bar a little more room to rotate upward when the axle is fully drooped. It's subtle, but given the geometry of everything, it should make somewhat of a difference. Also, I'll get around to removing and coating the aluminum spacers I made. For now, don't judge me (jk lol).What’s reasoning for the spacer?
