Heading to pick up the 2027 and...
Serial_TRXer
TRX of the Month 🏆
Castle Rock, CO
2023 Ram TRX
As soon as I got off the plane, the dealer called and said the digital cluster shut off. They scanned it and said ithe cluster needs to be replaced, but I'll definitely be checking the fuses. My other two TRXs had fuses not fully seated.
Anyone else run into this? Should I trust their scan?
Will be an interesting 800 mile drive home! 😎
I will say my fuses were not all seated, but instrument cluster was fine.
I have a high beam issue, believe it is related to the SCCM per a TSB. Also check that out.
