I bought oracle kit and having a local person install for around 250-300/headlight. Still come out cheaper than a replacement that may fail again.
Yea the price is stupid, I may try and do the swap and see if works, just a pain if it doesn’t work and then I to reassemble everything and wait for a new headlight.I did not. But, I do still have the none functioning passenger side headlight assembly. If this fix works I would definitely implement this fix to have an additional working unit. These assemblies are ridiculously expensive to just toss for a none working turn signal.
I ordered the board, should be here next week. I’ll report back.let use know if it works for you.
Thanks so much for the kind words, we really appreciate it! We're looking forward to hearing how the install goes once your board arrives.I ordered the board, should be here next week. I’ll report back.
Oracle, your stuff is awesome and thank you, but nobody in my area down here in FL will do the install. Otherwise I would the upgrade, that’s what I looked into doing first.
We saw your DM over the weekend and just responded. We'll be happy to help you with a fix using our DRL upgrade kit!Here to report that the board did not fix the problem. Still need a new headlight.
