When you’re looking at fender flares, what matters most? Is it how they look or how much tire they cover?
A lot of people add fender flares because they like how they look. A subtle flare can give the wheel wells a more finished, factory look, while a pocket-style flare can give the truck a more aggressive stance. Others add them after going with wider tires or wheels that push the tires farther out. That extra coverage can help keep some of the mud, gravel, and road spray the tires kick up off the sides of the truck. If coverage is what you’re after, start by measuring how far your tires stick out past the fenders. An OE-style flare might give you the look you want but come up short on coverage for your setup.
The exposed hardware can be a little misleading, too. Those bolts on pocket-style flares are often decorative, so that look doesn’t necessarily mean drilling into your truck. Installation varies by application, though, so check the instructions for the exact set you’re considering. In most cases, these are just going to be added to factory placements.
Paint-matching is another decision worth making early. It can give the flares a more factory appearance, but the prep and paint work need to be part of the budget.
One thing that deserves more attention is cleaning behind them. Flares help protect against kicked-up debris, but they can also collect dirt, salt, and moisture against the body. You’re gaining coverage while adding an area that needs regular cleaning, especially after winter driving.
We cover more of the styles, measuring, and installation details in our Complete Guide to Truck Fender Flares.
For those already running a set, how have they held up? Post your setup and pictures, along with anything you wish you’d known before installing them.
