I have spent quite a bit of time researching suspension, tire, and wheel upgrade options for my TRX (2023 Lunar Edition) and would appreciate some feedback from those who have already gone through this process.
I'm currently running the stock factory setup (18" beadlocks and Goodyears), and it is time to replace the tires……which is usually the time when I entertain a lift and going up a tire size. It just seems like the truck was made for 37s. New wheels is also an option as I would like to achieve a slightly more aggressive stance (just a little more poke) without any rubbing or potential trimming. I also want to ensure I do not “mess up anything” (i.e. suspension geometry, CV joints, electronic functionality, etc.). I do tend to over analyze decisions like this, but I had some issues with my TRD PRO Tundra when doing the same thing (leaning issues). I got it resolved, but I want to make sure get it right on a truck like this.
I am not an expert like many of you guys, so I would appreciate any recommendations, lessons learned, or things you would do differently if you were starting over. Pictures of your setups would be greatly appreciated, especially if you can include the lift configuration, tire size, wheel width, and offset. Thanks! I have more details below for those who don't mind reading the specifics.
Suspension upgrade: It looks like Eibach is the best option for maintaining the factory Bilstein setup or improving it. From what I have read here, the Eibachs are a little stiffer which I am fine with. I am considering the following configurations:
I'm currently considering:
Sorry for the long post. Appreciate all feeback.
Ryan
- Just the +1.6” Front only
- +1.6" Front / +1.5" Rear (slightly leaning this way)
- +2.7" Front / +1.5" Rear
- I am looking for a slight lift for some additional clearance if I jump up to 37s to keep the spacing ideal.
- I do like it level, but I honestly do not mind a slight rake either. I definitely do not want it nose high.
- Are there any additional requirements if doing the 2.7" vs 1.6" upfront (i.e. other parts to replace, alignment issues, ride height sensors, etc.).
- My truck is primarily street driven at this point.
- 35×12.50R18
- 37×12.50R18
- 37×13.50R18
- Would you recommend 12.50 or 13.50 width with the Eibach setup?
- Has anyone successfully run 37×12.50 KO3s on the factory wheels without a lift?
- Any hard opinions on load range? I want keep the speed rating up there as well.
- Any noticeable impact when moving up to 37s beyond what would be expected (i.e. acceleration, braking, fuel economy, overall responsiveness)?
- 18" vs. 20" wheels
- 9" vs. 9.5" wheel widths
- +12 mm vs. 0 mm offset (would not want more than that)
- I think I would prefer to stay with 18" wheels for the additional sidewall and ride quality, but I'm open to 20s.
- What wheel width and offset would you recommend for 37×12.50 tires? Would your recommendation change with 37×13.50 tires?
- Any hard opinion on cast vs forged? I know forged has several advantages, but is it worth the additional $$? I am primarily interested in forged just for the lighter weight with larger tires to try and keep the new combined weight at or below factory setup.
Ryan
