LV_TRX
Just installed my new Console Vault for TRX part # 1122-4D https://www.consolevault.com/dodge-ram-150025003500-low-profile-2019-current-.html#.YXgziJ7MLL-
Easy install, depth of secured compartment is 5"-6" deep - excellent storage area...
I had purchased a Console Vault in April (Part 1093-3D) that Console Vault said would fit, but it didn't. They took it back as a return.
Have been in touch with Lock R Down, very nice people, but they have promised delivery of a unit for months. but haven't come through.
Recent Post on this Forum showed Console Vault 1122 would fit, but OP showed pictures and reported that the DEPTH was only 2"-3".
I received the 1122 unit yesterday, installed last night HIGHER UP and ended up with 5"-6" DEPTH for locked portion.
Dimensions of Unit (per Manufacturer) is 9.75" L x 10.5" W x 2.25" D - but that is the depth of the physical "rim" of the console vault. The locked portion is much deeper if you install the unit higher up....
Install Notes:
1) I Held the unit up as HIGH as possible (free-floating) and lined up front end first. Hand insert and tightened supplied screws to hold in place. Hand tightened easily supports weight of unit.
2) Ended up slightly angling the unit upward towards the front (front just slightly higher than rear), as it just seemed to "fit" best. Bonus, slightly better visual and physical access to the rear of the compartment.
3) Would be a little bit easier with second pair of hands, but very doable alone with a bit of dexterity
4) Unit does NOT fit snug. There is a bit of play. Makes it easier to install. Can see that there is slight gapping at rear "tabs", but contents of vault clearly secure.
Install Notes:
