Wonder what else these trucks are missing?
Unless things have changed, one example would be the proper amount of fluid in the diffs.Wonder what else these trucks are missing?![]()
That looks like aftermarket lol.
I did the same, did a sticker delete on my 27. Even on my 24 I removed that, I actually think it looks better without it. If you have your car correctly ppf they have to remove it anyway...I had one on mine. The last truck I had black decals like these (2005 1500 Daytona). After a few years they will turn grey. I opted out of the hood and bed side decals. I also removed the decal in front of the hood scoop right after I bought it.
I haven't heard any recent complaints on under filled diffs…BUT, plan on changing your rear diff fluid between 2500-5000 miles…not sure if they are using different gear material or the gears are being over-shimmed, but your fluid will look like glitter-flake within 5K miles.Unless things have changed, one example would be the proper amount of fluid in the diffs.
I put a magnetic fill plug in them before driving for the first time, then change the fluid at 500 miles or so, or at least before 1,000.I haven't heard any recent complaints on under filled diffs…BUT, plan on changing your rear diff fluid between 2500-5000 miles…not sure if they are using different gear material or the gears are being over-shimmed, but your fluid will look like glitter-flake within 5K miles.
