- Joined
- Jul 14, 2020
- Messages
- 3,556
- Gallery
- 1,095
- Reaction score
- 2,642
- Location
- Central Florida
- Current Ride
- 2022 Ram TRX - AWE Exhaust, J&L Catch Can, Sentry CT Tonneau Cover, Tons of Rigid Lights, Weld 20x9 +0 Black Ledge Wheels, 35.5 BFG KO2s, Eibach Front Leveling Springs, aFe Pro 5R Intake.
- Current Ride #2
- Wrangler 392
Good Evening everyone!
We have Seven Rear Sway Bar Kits by Hellwig for the TRX ready to ship out tmw!
Grab one up here and we'll get it out ASAP: https://justboltons.com/hellwig-rear-stabilizer-sway-bar-for-2021-2023-ram-trx-7794/
The Hellwig Rear Stabilizer Sway Bar is designed to be a direct replacement for the factory sway bar on the 2021-2024 Ram TRX. It is made from high-quality materials, including heat-treated chromoly steel, which makes it extremely strong and durable. The sway bar is also powder-coated for added protection against the elements.
The Hellwig Rear Stabilizer Sway Bar is engineered to be larger than the factory sway bar, which helps to reduce body roll and improve handling. The sway bar has a 1-1/4 inch diameter, compared to the factory sway bar's 1-inch diameter. This larger diameter allows the sway bar to resist more body roll, which means you can take corners faster and with more confidence.
- Solid, heat treated chromoly, rear sway bar
- Increased stiffness for improved handling, comfort and safety
- Everyday drivability and in heavy, tow/haul conditions
- Adjustable Rate Sway Bar
