Would that be K5e ?No, you typed it correctly. K5s means it's plural. K5's would mean it's possessive, like "the K5's tires."
Nobody denies the benefits of moly. And that’s why a lot of oils have it already. So much for a well kept secret, I guess. It is actually employed as a friction modifier FIRST for fuel economy, but secondary anti-wear benefits have been shown at 200-300 PPM depending upon type. Most of the boutique oils have at least that amount in a very effective trinuclear form, so if you want more moly, just keep running one of those!Anyone believe this??
Are you insinuating that not everything on You Tube is true and very educational?With all apologies to the compelling AI generated Japanese man, blindly dumping the solid particle form into a modern, fully formulated engine oil is just not the way the citied studies found improvements. At best it does nothing.
