Annoying clicking from rear shocks
Joncayman
Cayman Islands
Ram trx
Trx
No
As title states have a very annoying clicking sound and seeing if anyone has had this before. Can re create with jumping on back bumper. So far changed both rear shocks to new, c pillar and b pillar mounts and tightened all bolts. Can stop the noise if I pull on shock but can’t find how to stop it as comes right back.
Things to check:
1) bolt torque
2) are the bolts bent (lower often bends)
3) are the holes on the mounts ovaled. If the bolts come loose and the truck is driven, the bolt holes on the frame and axle can oval.
4) are they using the correct diameter bolt.
Things to check:
1) bolt torque
Will get this checked asap, what is the part number for upper bolts? I tried to order new bolts but they came to short.
If hole is oval how do I rectify?
You would have to weld a spacer on
Let me find the PN for the bolts. I went to aftermarket shouldered bolts
Check this thread for bolts
The PN are in that thread (links to McMaster Carr)
Posts 9,10 and 11
Posts 9,10 and 11
Thank you for all your help! Hopefully will get sorted this week and get this noise gone.
Found this company for washers
