Installed the Ampire immobilizer tonight. Allow yourself about 4 hours, but much of this will be accessing a good location and hiding your tracks. Follow
@OnTheReel 's advice, use service info to find a good location and Do Not Use the location in the instructions, which is way too obvious. This video shows the most complex part of the install, which is tapping into the four wires, power/ground/CAN+/CAN-
I used the soldering iron to clear a splice location instead of wire strippers.
The sequence to start is: with foot off brake, push start twice (ACC-RUN), enter sequence of steering wheel buttons, push brake, and hit start. Works like a champ. I'm also keeping my Mobilistics relay, with a cable lock around the fuse box.
Thread '$15 locking fuse box (for Mobilistics or other relay devices)'
https://www.ram-trx.com/threads/15-locking-fuse-box-for-mobilistics-or-other-relay-devices.13237/
