DEAL aFe Momentum GT Cold Air Intake (Pro 5R or DRY S) For 2021+ Ram TRX @ JustBoltOns.com
Johnny@JustBoltOns
TRX Maniac
Central Florida
Wrangler 392
2021+ Ram TRX aFe Momentum GT Cold Air Intake (Pro DRY S or Pro 5R Filters) System.
Not CA CARB Approved - Can't Be Shipped to California. Available in December 2021! Pre-Orders open today!
  • Dyno-Proven Gains up to +22 HP and +19 Lbs. x Ft. TQ on Pro DRY S
  • Dyno-Proven Gains up to +28 HP and +25 Lbs. x Ft. TQ on Pro 5R
aFe Momentum GT Cold Air Intake (Pro DRY S Filters) for 2021+ Ram TRX - 50-70075D
aFe Momentum GT Cold Air Intake (Pro DRY S Filters) for 2021+ Ram TRX - 50-70075D 2.jpg
Shop with confidence at Just Bolt-On Performance Parts for the best customer servicing, pricing and shipping on aFe Momentum GT Cold Air Intake (Pro DRY S Filters) for 2021+ Ram TRX - 50-70075D.
  • Washable and Reusable Pro DRY S Air Filter for Maximum Convenience
  • Innovative Filter-to-Housing Interface for Easy Installation
  • Massive Clear Sight Window for Convenient Filter Inspection Without Disassembly
  • Sealed Housing Incorporates Factory Hood Inlet Scoop and Grille Air Inlet
  • Premium T-Bolt Clamps and a Silicone Couplings Provide a Secure Seal and Excellent Durability
Dual Three Layer Performance Air Filters: A pair of 360-degree radial flow air filters feature our oil-free Pro DRY S media with three layers of synthetic media for maximum convenience. The progressive layering provides great filtration efficiency and dust holding capacity, while not requiring the use of oils. This media is best suited for street and light off-road use. The inverted tops makes for more filter surface area, resulting in longer service intervals.
aFe Momentum GT Cold Air Intake (Pro DRY S Filters) for 2021+ Ram TRX - 50-70075D 3.jpg
aFe Momentum GT Cold Air Intake (Pro 5R Filters) for 2021+ Ram TRX - 50-70075R
aFe Momentum GT Cold Air Intake (Pro 5R Filters) for 2021+ Ram TRX - 50-70075R 2.jpg
Shop with confidence at Just Bolt-On Performance Parts for the best customer servicing, pricing and shipping on aFe Momentum GT Cold Air Intake (Pro 5R Filters) for 2021+ Ram TRX - 50-70075R.
  • Washable and Reusable Pro 5R Air Filter for Maximum Performance
Dual Five Layer Performance Air Filters: A pair of 360-degree radial flow air filters feature our pre-oiled Pro 5R media with five layers of progressively finer cotton gauze media for maximum performance. Our Pro 5R media provides your engine with the largest amount of high-flowing air, usually resulting in the highest power gains out of all other filter media options. This media is perfect for street use. The inverted tops make for more filter surface area, resulting in longer service intervals.
aFe Momentum GT Cold Air Intake (Pro 5R Filters) for 2021+ Ram TRX - 50-70075R 3.jpg
aFe Momentum GT Cold Air Intake (Pro DRY S Filters) for 2021+ Ram TRX - 50-70075D 4.jpg
Unique One-Piece Housing: The smooth one-piece sealed housing, constructed of heat-resistant cross-linked polyethylene (XLPE), features our patent pending filter-to-housing interface. Its innovative design minimizes the total number of parts, making for an easy installation. A massive clear sight window allows for hassle-free filter inspection without having to disassemble your intake system. The housing incorporates both the factory hood air inlet scoop and the grille inlet using no additional hardware.
Dyno-Tuned Intake Tube: This system features a trio of high quality, computer-designed, dyno-tuned intake tubes to achieve maximum power gains while maintaining a perfect fit. Our XLPE material is heat soak resistant and extremely durable.
Premium Components: Stainless-steel T-bolt clamps are included for strength, and a premium silicone coupling allows for ample flexibility and durability. Momentum GT intakes are designed with fewer parts for a fast and easy installation.
Emissions Disclaimer: This product is not currently CARB exempt and is not available for purchase in California or for use on any vehicle registered with the California Department of Motor Vehicles.
aFe Momentum GT Cold Air Intake (Pro DRY S Filters) for 2021+ Ram TRX - 50-70075D 6.jpg
Damn, I just ordered mine from them yesterday. I live in CA and they took my order, so here's hoping they decide to ship it anyways:sneaky:
Someone let me know how this intake performs!
They said " Dyno-Tuned Intake Tube: This system features a trio of high quality, computer-designed, dyno-tuned intake tubes to achieve maximum power gains while maintaining a perfect fit. Our XLPE material is heat soak resistant and extremely durable. "
So what are the numbers????
Damn, estimated release date is 12/10?
Reactions: Bob
They are claiming late NOV right now but seeing all the delays we see often, I'm estimating DEC right now.
Most cold air intakes do very little on modern cars - I'd like to see some dyno data before spending on one! (And not from the manufacturer....AFE throws a lot of numbers out, but it's rare to see field data that supports it.) Most manufacturers are optimizing the stockers as much as possible....not like the old days.
Maybe the increased air requirements of a SC engine change this?
Are there 3 different tubes or three tuned tubes in the assembly?
Cheaper option....even if you get 2...
Exhaust Whistler
Washingtonian
2.0 out of 5 stars Not meant for pansy cars
Reviewed in the United States on August 9, 2021
Verified Purchase
I’m a teen in Washington that is involved in the huge modification of cars group. Although I’m grateful I have a car I have a Hyundai Elantra so I bought this hoping it would give my car a little umf and all I go when I hooked it up was something that sounds like a gym teacher whistle. My dad has a Dodge Durango RT hooked it up to his car and it worked how it was supposed to do if you’re looking at this product make sure your car already has a good growl to it.
Saw that in the review... lol wow...
Washingtonian
Verified Purchase
The evolution of the ricer fart can. The tailpipe whistle.
