aFe differential cover AND fluids changed at 700 miles
HorsePowerObsessed
Pittsburgh, PA & Hollywood, Florida
2027 RAM SRT TRX
2025 Corvette Z06 (twin turbo)
At only 700 miles I wanted to make sure I had all of the break-in fluids changed and figured I'd change out the diff cover in the rear while I was at it. I have seen a few questions about it pop up on the forum here and wanted to share my experience. Install of the cover was pretty easy and straightforward. It now holds 4 quarts of diff fluid instead of the factory 2.5. I changed my oil, front and rear differential fluid, and transfer case fluid. I mostly did this because I've heard a lot of reports of these coming underfilled from factory, and while I can't confirm that they were underfilled, I can tell you that none of them had any fluid come out from the fillport when that was removed, so they definitely could've used a little bit of a topping off. I love the way this new differential cover looks. Especially after removing the spare tire underneath. Let me know what you guys think. Hope this is useful to somebody out there!
