2027 TRX First oil change
GGarza91
Texas
2027 Ram SRT TRX
At how many miles should you do first oil change? Is it at 500 miles or is waiting til 1,000miles good?
That is up to you. I did mine early as I believe most do. 3 times in the first few thousand. Oil is way cheaper than other bills that can arise! On the old every 3500 miles now, I would rather change my oil early than late. Your truck so it's your choice. I'm sure others will chime in with good info. There might also be an older thread about this as well.
Thank you! I think I will do the same.
I have 1150 on mine. Changed at 500 and will again at 2500. Then regular schedule. I use Amsoil Signature oil and their EAO11 filter.
Every hemi i have owned (392 and Hellcat) i have done 500,1500,3000,5000 intervals.......and then every 2500-3000 thereafter depending upon how heavy my foot was that interval period. None of the engines have ever burned a drop of oil per what i monitor on the dip stick
One extremely important thing i would recommend that is not talked about enough is during break in, you don't want to beat the shit out of it out the box but its not good to baby the engine either. you really need to thread the needle and make sure you are also working the rpm band during those first 500 miles to really make sure the piston rings are set in well......by no means red line the car but you def should get some harder accelerations in there up to 4500-5500rpm as well.
Thanks for the info! I’m barely at 240 miles and have been babying it.
What oil filter is everyone using on their 2027 TRX?
My dealer checked the Ram catalog and found part #4884899WC, but it’s showing as unavailable. I’m looking at the Mopar MO-899 (#4884899AC) listed for the 2024 TRX.
Has anyone confirmed with their dealer whether the MO-899 is also approved for the 2027? Trying to get everything together for my first oil change also.
