@RamCares
The 2027 TRX owners manual says to use 0W-40 engine oil meeting MS-6395 spec. This spec is a Chrysler spec for other lower performance engines with lower weight oils. Chrysler has always used a higher spec MS-A0921 (replaced MS-12633) for the Hellcat engine, which is a 0W-40 Oil.
Can you confirm which spec should be used in the 2027 TRX Hellcat engine???
