2019-2024 RAM 1500 TRX RamBar - 7-Pod PRO Lighting Setup
M&R automotive
burbank
19 Ram
2019–2024 RAM 1500 TRX RamBar Lighting Setup
For the TRX guys running a RamBar or bed cage, we have a setup with seven 80W LED pods to light things up around the back of the truck.
You can choose between spot or flood beam patterns depending on whether you want more distance or wider coverage. Each pod also has a white main beam with an amber DRL backlight.
Feel free to ask any questions!
Here's the full setup:
ram1500-trx-rambar-lights-install-kit-spot-vs-flood-beam-mounting-brackets-2019-2024.webp
For the TRX owners running a RamBar or bed cage, here's another look at the 7-pod lighting setup. With the option to go spot or flood on the pods, you can set it up for the kind of coverage you're after.
All seven have white main beams with amber DRL backlighting.
More details here:
