New Product! OffroadAlliance.com 1.5" Front Leveling Kit
offroadalliance
Boston
TRX
Improve the looks and the ride of your Ram TRX with the new OffroadAlliance.com 1.5" Front Perch Collar Leveling Kit. Like all trucks on the market, the TRX comes from the factory with a slightly "nose-down" stance. Adding our leveling kit to the front shocks of you TRX not only improves the overall look and stance of your truck, but also allows for the installation of 37" tires and/or lower offset wheels without risk of damaging the suspension or the tires rubbing the fenders under normal driving conditions.
Price: $379.99
Ram TRX Leveling Kit Features:​
  • Made in the U.S.A.
  • Fast and Easy Installation
  • Precision CNC Machined from Aerospace Grade Aluminum
  • Type II Black Anodized Finish
  • Lifetime Warranty
  • Unmatched Customer Support
There are many considerations to make when choosing a leveling kit for your TRX:
Looks:
As the name would suggest, a Leveling Kit should cause the truck to appear perfectly level on flat ground. While other options on the market create a nose-high or slightly nose-down stance, our leveling kit has been designed to create a perfectly level stance front to back - no more, no less.
Suspension Geometry: The OffroadAlliance.com TRX Leveling Kit is a spring perch spacer that gets installed underneath the spring which lifts the truck up by adding spring preload. The total suspension travel does not change, which prevents CV and ball joint binding that can occur with spacers that are installed on top of the spring assembly.
Ride Quality: The Ram TRX front coilover springs have a very high spring rate from the factory to help the truck soak up large bumps during aggressive and high-speed offroading. Adding too much pre-load to the front coilover springs such as other kits on the market do can create a harsh rebound effect over sharp bumps on the road and off. The OffroadAlliance.com TRX Leveling System only lifts the truck 1.5" and does not negatively affect the ride dynamics of the vehicle whatsoever. You can expect a slightly firmer ride with less nosedive under hard braking, but no harshness.
Ease of Installation: Our TRX Leveling Kit can be installed without disassembling the coilover assembly. Each spacer is made in two halves that will slide under the spring and get bolted together during final installtion. Our unique design also features a rotational indexing cutout on the bottom of the spacer that helps to align the spacer with the shock body during installation.
Product Quality: The OffroadAlliance.com TRX Leveling System is precision CNC machined from Aerospace grade aluminum in the United States of America and finished with a Type II Black Anodized finish. All Stainless Steel hardware is included.
Will 37s Fit? Yes! We recommend 18"-20" x 9" wheels with 0mm to +18mm offset if installing 37"x12.50" or 37"x13.50" tires. Some rubbing may occur with 37"x13.50" tires with 0mm or lower offset off-road. If you plan to off-road your truck extensively, we recommend staying close to the stock wheel offset (+18mm) if installing 37" x 13.50" tires. The TRX in the product photos is equipped with 0mm offset 18 x 9" wheels and 37x12.50R18 Toyo Open Country ATIII Tires.
Buy Now at OffroadAlliance.com
Hi, can you post the installation instructions?
